connect my normal "non-smart" doorbell to domoticz?
Posted: Thursday 17 December 2015 23:29
by Evelen
Hi.
I have a standard normal cable-doorbell.
Like this:
Is it possible to connect this to domoticz in anyway?
I think maybe it exist some 433MHz device i can connect to some of the wires in the box?
Any tips?
http://www.explainthatstuff.com/how-ele ... -work.html
Re: connect my normal "non-smart" doorbell to domoticz?
Posted: Friday 18 December 2015 7:27
by ThinkPad
KaKu has some product for this:
http://www.klikaanklikuit.nl/shop/nl/be ... cdb-7000b/ but BEWARE: you can't connect this straight to the wires in your doorbell. You will need some sort of relay, the white wires on the KaKu thingy are supposed to be made contact when button is pressed, not directly connecting them to the 8V AC of your transformer
Build it like this:
Doorbell - 8V AC relay - KaKu thingy (or self built)
And it will work. See also here:
https://gathering.tweakers.net/forum/li ... %5D=finder
If you are very handy, you could also modify a cheap 433Mhz remote and use that together with some components:
http://thinkpad.tweakblogs.net/blog/120 ... aar-433mhz
Posted: Friday 18 December 2015 7:34
by jannl
A binary zwave switch could do about the same. But also a seperate powersupply is needed.
Posted: Friday 18 December 2015 10:37
by ThinkPad
jannl wrote:A binary zwave switch could do about the same. But also a seperate powersupply is needed.
I have my router and stuff also in the meter cabinet (where the bell and transformer resides), my cheap 433Mhz uses a 12V battery. I made a Y-wire, so that i can leech 12V from my router
You could do the same with the binary sensor (if you prefer Z-Wave), it doesn't need that much power i think.
Posted: Friday 18 December 2015 10:40
by D'rMorris
Or you could use an Arduino, like described
here.
The Arduino needs 3.3V, you could take that from the transformer by using step-up / step-down modules.
However: this requires also an Arduino gateway connected to Domoticz. They're very cheap, but if you already have z-wave, I can imagine that you do not want to add yet another protocol.
Posted: Thursday 21 July 2016 10:58
by sincze
Haha damn.
Great idea the Arduino solution.
I already had the ACDB7000 so I used the relais solution running separate from my existing doorbell.
Great descriptions on how to do this can be found here:
http://eye-vision.homeip.net/5994/draad ... ment-67455
And here:
http://www.nodo-domotica.nl/forum/viewt ... =12&t=1572
Wiring things up
Components needed: RELAIS for the appropriate voltage:
This is how Henri did his wiring:
So I ended op like this:
- Doorbell
- doorbell.jpg (323.28 KiB) Viewed 3106 times
