connect my normal "non-smart" doorbell to domoticz?
Evelen
Domoticz version: 2.4538
Post by Evelen »
Hi.
I have a standard normal cable-doorbell.
Like this:
Is it possible to connect this to domoticz in anyway?
I think maybe it exist some 433MHz device i can connect to some of the wires in the box?
Any tips?
http://www.explainthatstuff.com/how-ele ... -work.html
ThinkPad
Re: connect my normal "non-smart" doorbell to domoticz?
Post by ThinkPad »
KaKu has some product for this: http://www.klikaanklikuit.nl/shop/nl/be ... cdb-7000b/ but BEWARE: you can't connect this straight to the wires in your doorbell. You will need some sort of relay, the white wires on the KaKu thingy are supposed to be made contact when button is pressed, not directly connecting them to the 8V AC of your transformer
Build it like this:
Doorbell - 8V AC relay - KaKu thingy (or self built)
And it will work. See also here: https://gathering.tweakers.net/forum/li ... %5D=finder
If you are very handy, you could also modify a cheap 433Mhz remote and use that together with some components: http://thinkpad.tweakblogs.net/blog/120 ... aar-433mhz
jannl
Domoticz version: 2026.1.x
Post by jannl »
A binary zwave switch could do about the same. But also a seperate powersupply is needed.
ThinkPad
Post by ThinkPad »
jannl wrote:A binary zwave switch could do about the same. But also a seperate powersupply is needed.
I have my router and stuff also in the meter cabinet (where the bell and transformer resides), my cheap 433Mhz uses a 12V battery. I made a Y-wire, so that i can leech 12V from my router ;)
You could do the same with the binary sensor (if you prefer Z-Wave), it doesn't need that much power i think.
D'rMorris
Post by D'rMorris »
Or you could use an Arduino, like described here.
The Arduino needs 3.3V, you could take that from the transformer by using step-up / step-down modules.
However: this requires also an Arduino gateway connected to Domoticz. They're very cheap, but if you already have z-wave, I can imagine that you do not want to add yet another protocol.
sincze
Domoticz version: 2024.4
Post by sincze »
Haha damn.
Great idea the Arduino solution.
I already had the ACDB7000 so I used the relais solution running separate from my existing doorbell.
Great descriptions on how to do this can be found here:
http://eye-vision.homeip.net/5994/draad ... ment-67455
And here:
http://www.nodo-domotica.nl/forum/viewt ... =12&t=1572
Wiring things up
Components needed: RELAIS for the appropriate voltage:
This is how Henri did his wiring:
So I ended op like this:
Doorbell
Doorbell
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
