Rounding setting for kWh meters etc.
bbqkees
Domoticz version: 4.1x
Post by bbqkees »
I want to make a suggestion for the kWh meters.
The overview panel is too accurate.
It shows the total usage in 3 decimals, which is not necessary at all.
It would be nice if there would be a rounding setting in the Settings menu for this.
So one setting for W(h) and one for kW(h).
One decimal or even zero would be sufficient for a better overview.
MightyMaik
Re: Rounding setting for kWh meters etc.
Post by MightyMaik »
If this could we implemented it would be great! I would like to see an option to remove the decimals in the overview... :D 8-) :D
Flopp
Post by Flopp »
+1
For Watt and Today, 2 or 3 decimals can be OK.
For Total, none or 1 decimal is OK.
juankar
Post by juankar »
Perhaps for some devices 1 kWh be a little value, think about a swimming pool motor or so. But if you think in lights or a TV or a freezer... 1 kWh is a high quantity. Example: a led light consumes about 10 watts it needs about 100 hours! for 1 kwh. In this situation 1 kwh is too big and we need decimals, in the example this light working for 5 hours (I think it's a good media) consumes about 0,05 kWh so we need 2 decimals.
Today electric device in our homes are more efficient and need less energy than some years ago.
Perhaps a good idea would be to create a property to set the number of decimals in a counter device.
