Philio Technology Corp
Website:
http://www.philio-tech.com
Function:
PAN04 In Wall Switch Module with meter dual relay single contact 2X1.5KW (NOT dry)
Z-Wave GEN5
No
Superseded by Philio PAN04-1B: Z-Wave+ AKA Gen5
Family members:
PAN05 In Wall Switch Module 3kW
PAN06 In Wall Switch Module 2X1.5KW (single dry contacts)
PAN07 In Wall Switch Module 2X1.5KW dual contacts
PAN08 In Wall Switch Module Roller shutter
PDF with schematic electrical overview
Family overview
Rebranding:
Zipato PAN-04,
TKB-TZ04,
have seen more?
Device Library from http://www.pepper1.net
http://www.pepper1.net/zwavedb/device/610
Manuals from manuals.zwaveeurope.com and doc.eedomus.com:
manuals.zwaveeurope.com: web page
doc.eedomus.com PDF
Scan of user documentation version 1B Hosted by https://www.betaalbare-domotica.nl
Domoticz experience
Hardware: Remarks:
3 operational. No polling needed. Reliable switches
In the last 2 year a few time lost connection.
They give an average contribution to the Z-Wave network.
Configuration: Devices zwcfg_0xaaaaaaa.xml sample:
<Node id="9" name="Pump_FF_and_man" location="" basic="4" generic="16" specific="1" type="Binary Power Switch" listening="true" frequentListening="false" beaming="true" routing="true" max_baud_rate="40000" version="4" query_stage="Complete">
<Manufacturer id="013c" name="Philio Technology Corporation">
<Product type="0001" id="0003" name="PAN04-1 Double Relay Switch 2x1.5kW with Power Measurement" />
</Manufacturer>
<CommandClasses>
<CommandClass id="37" name="COMMAND_CLASS_SWITCH_BINARY" version="1" request_flags="5">
<Instance index="1" endpoint="1" />
<Instance index="2" endpoint="2" />
<Instance index="3" endpoint="3" />
<Value type="bool" genre="user" instance="1" index="0" label="Switch" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="True" />
<Value type="bool" genre="user" instance="2" index="0" label="Switch" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="True" />
<Value type="bool" genre="user" instance="3" index="0" label="Switch" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="True" />
</CommandClass>
<CommandClass id="39" name="COMMAND_CLASS_SWITCH_ALL" version="1" request_flags="5">
<Instance index="1" />
<Value type="list" genre="system" instance="1" index="0" label="Switch All" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="3" size="1">
<Item label="Disabled" value="0" />
<Item label="Off Enabled" value="1" />
<Item label="On Enabled" value="2" />
<Item label="On and Off Enabled" value="255" />
</Value>
</CommandClass>
<CommandClass id="50" name="COMMAND_CLASS_METER" version="3" request_flags="3">
<Value type="decimal" genre="user" instance="1" index="0" label="Energy" units="kWh" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0.0000000" />
<Value type="decimal" genre="user" instance="1" index="1" label="Previous Reading" units="kWh" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0.00" />
<Value type="int" genre="user" instance="1" index="2" label="Interval" units="seconds" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="16382" />
<Value type="decimal" genre="user" instance="1" index="8" label="Power" units="W" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="1.0" />
<Value type="decimal" genre="user" instance="1" index="9" label="Previous Reading" units="W" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0.0" />
<Value type="int" genre="user" instance="1" index="10" label="Interval" units="seconds" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="32" />
<Value type="decimal" genre="user" instance="1" index="16" label="Voltage" units="V" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="227.1" />
<Value type="decimal" genre="user" instance="1" index="20" label="Current" units="A" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0.27" />
<Value type="decimal" genre="user" instance="1" index="24" label="Power Factor" units="Power Factor" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0.96" />
<Value type="bool" genre="user" instance="1" index="32" label="Exporting" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="False" />
<Value type="button" genre="system" instance="1" index="33" label="Reset" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
<Value type="decimal" genre="user" instance="2" index="0" label="Energy" units="kWh" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0.31" />
<Value type="decimal" genre="user" instance="2" index="1" label="Previous Reading" units="kWh" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0.00" />
<Value type="int" genre="user" instance="2" index="2" label="Interval" units="seconds" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="16381" />
<Value type="decimal" genre="user" instance="2" index="8" label="Power" units="W" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="57.3" />
<Value type="decimal" genre="user" instance="2" index="16" label="Voltage" units="V" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="227.3" />
<Value type="decimal" genre="user" instance="2" index="20" label="Current" units="A" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0.27" />
<Value type="decimal" genre="user" instance="2" index="24" label="Power Factor" units="Power Factor" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0.95" />
<Value type="bool" genre="user" instance="2" index="32" label="Exporting" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="False" />
<Value type="button" genre="system" instance="2" index="33" label="Reset" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
<Value type="decimal" genre="user" instance="3" index="0" label="Energy" units="kWh" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0.00" />
<Value type="decimal" genre="user" instance="3" index="1" label="Previous Reading" units="kWh" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0.00" />
<Value type="int" genre="user" instance="3" index="2" label="Interval" units="seconds" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="16382" />
<Value type="decimal" genre="user" instance="3" index="8" label="Power" units="W" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0.0" />
<Value type="decimal" genre="user" instance="3" index="16" label="Voltage" units="V" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="227.1" />
<Value type="decimal" genre="user" instance="3" index="17" label="Previous Reading" units="V" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="409.6" />
<Value type="int" genre="user" instance="3" index="18" label="Interval" units="seconds" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="4096" />
<Value type="decimal" genre="user" instance="3" index="20" label="Current" units="A" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0.00" />
<Value type="decimal" genre="user" instance="3" index="24" label="Power Factor" units="Power Factor" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0.00" />
<Value type="bool" genre="user" instance="3" index="32" label="Exporting" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="False" />
<Value type="button" genre="system" instance="3" index="33" label="Reset" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
</CommandClass>
<CommandClass id="96" name="COMMAND_CLASS_MULTI_INSTANCE/CHANNEL" version="3" request_flags="1" mapping="endpoints">
</CommandClass>
<CommandClass id="112" name="COMMAND_CLASS_CONFIGURATION" version="1" request_flags="5">
<Value type="short" genre="config" instance="1" index="1" label="Watt meter report period" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="1" max="32000" value="20">
<Help>If the setting is configured for 1hour (set value =720), the device will report its instant power consumption every 1 hour to Z-Wave Controller. Unit: 5 seconds.</Help>
</Value>
<Value type="short" genre="config" instance="1" index="2" label="kWh meter report period" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="1" max="32000" value="720">
<Help>If the setting is configured for 1hour (set value =720), the device will report its power consumption in KWh every 1 hour to Z-Wave Controller. Unit: 5 seconds.</Help>
</Value>
<Value type="byte" genre="config" instance="1" index="3" label="Selected end point" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="3" value="1">
<Help>1: Relay 1 and Relay 2. 2: Relay 1. 3: Relay 2</Help>
</Value>
<Value type="byte" genre="config" instance="1" index="4" label="Edge or Pulse mode or Edge-Togle mode" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="3" value="2">
<Help>Edge or Pulse mode or Edge-Togle mode defines the operating mode of the externally connected switch. Default: Edge Mode</Help>
</Value>
<Value type="short" genre="config" instance="1" index="5" label="Threshold of Watt for Load Caution" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="10" max="1500" value="500">
<Help>Threshold of Watt for Load Caution</Help>
</Value>
<Value type="short" genre="config" instance="1" index="6" label="Threshold of kWh for Load Caution" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="10000" value="500">
<Help>Threshold of kWh for Load Caution</Help>
</Value>
</CommandClass>
<CommandClass id="114" name="COMMAND_CLASS_MANUFACTURER_SPECIFIC" version="1" request_flags="5">
</CommandClass>
<CommandClass id="133" name="COMMAND_CLASS_ASSOCIATION" version="1" request_flags="5">
<Associations num_groups="3">
<Group index="1" max_associations="1" label="Relay 1 and 2 together" auto="false">
<Node id="1" />
</Group>
<Group index="2" max_associations="1" label="Relay 1" auto="false">
<Node id="1" />
</Group>
<Group index="3" max_associations="1" label="Relay 2" auto="false">
<Node id="1" />
</Group>
</Associations>
</CommandClass>
<CommandClass id="134" name="COMMAND_CLASS_VERSION" version="1" request_flags="5">
<Value type="string" genre="system" instance="1" index="0" label="Library Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="3" />
<Value type="string" genre="system" instance="1" index="1" label="Protocol Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="3.41" />
<Value type="string" genre="system" instance="1" index="2" label="Application Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="1.00" />
</CommandClass>
</CommandClasses>
</Node>Comparable with the somewhat smaller Qubino and Fibaro family of build-in switches.
(where Qubino has the advantage of a DS18B20 connetion)
The Philio PAN04-1 has a trouble free connection to Domoticz.
Voltage measurement, Load measurement, overload protection and alarm.
Instantaneous and cumulative energy usage per switch and for the device as whole.
Reliable switching even with an inductive load (for 2 years now).
Dual relay can be switched as one.
Feedback on local switching to Domoticz.
Curious how the Philio PAN04-1B is doing.
Any experiences?
Hope to see a fact file for the Philio PAN04-1B.
Hope this helps
Domosapiens
