Read Thermostat in devicechanged table
mirage
Post by mirage »
Domoticz just gets better and better.
I've just realised that there is now a thermostat device available. I have created a dummy thermostat which now appears on the web interface. When I change the temperature I want to execute a Perl script to communicate with my heatmiser thermostat.
The scripting is fine and my device.other script triggers fine when I change the value in the browser. I just cant see for the life of me how to read the new thermostat value in LUA.
I tried:
devicechanged_svalues['Thermostat']
devicechanged_temperature['Thermostat']
jvdz
Domoticz version: 4.107
Re: Read Thermostat in devicechanged table
Post by jvdz »
Something like this:
otherdevices_svalues['Thermostat']
Jos
JuanUil
Domoticz version: 4.11083
Post by JuanUil »
How can you make a dummy thermostat????
jvdz
Post by jvdz »
Go to the Setup/Hardware page.
Create a Dummy entry in case you don't have it yet.
Click on the "Create virtual Sensor" button on the Dummy hardware and select "Termostat setpoint".
Jos
Egregius
Domoticz version: v2024.7
Post by Egregius »
Those are there since long, I'm using setpoints since begin 2015 in scripts.
mirage
Post by mirage »
Thanks Jos,
That worked. I just thought I should read the devicechanged table when a device changes, but otherdevices contained the correct value.
The other reason it failed for me even when using otherdevices is that I had a print command to log the value but forgot to return the commandArray. I never realised that this means that the script doesnt execute.
Raj
angusmurray
Post by angusmurray »
Raj,
Sorry, but can you point me at instructions on how to interface the heat miser with domoticz? I have a wifi heat miser (not neo, the old kind), I have a switch setup to boost the hot water and heating, but would like to track the temperature in domoticz. Are you able to give more info on how to do it?
many thanks
Angus
benp
Domoticz version: V4.10717
Post by benp »
Look at this post:
http://www.domoticz.com/forum/viewtopic ... 56&t=12099
This is for Heatmiser PRT, not Neo
I don't know which one it is here...
Domoticz V2024.7
