SOLVED: Problem with LUA
RobertH
Post by RobertH »
I have 2 lua scripts called: script_device_dimmerstue.lua and script_device_dimmersoverom.lua
The first one was added first and is working, nothing happens on the second one but I can see the buttons beeing reffered to is triggered in the log.
First script:
if (devicechanged['Stue dimmer S2 1 click'] == 'On') then
   commandArray['Group:LivingRoom']='On'
   elseif
   (devicechanged['Stue dimmer S2 2 click'] == 'On') then
   commandArray['Group:LivingRoom']='Off'
   elseif
   (devicechanged['Stue dimmer S2 3 click'] == 'On') then
   commandArray['Group:Alt lys']='Off'
Second script:
if (devicechanged['Soverom dimmer S2 1 click'] == 'On') then
   commandArray['Group:Soverom']='On'
   elseif
   (devicechanged['Soverom dimmer S2 2 click'] == 'On') then
   commandArray['Group:LivingRoomAndSoverom']='Off'
   elseif
   (devicechanged['Soverom dimmer S2 3 click'] == 'On') then
I have double checked that all the references are correct.
Is there some sort of conflict going on here?
Also after I added the last script the first one is much slower to trigger so I guess there is something strange going on here.
Domoticz running on Windows Server 2008 in VMware (ESXi), UZB1 stick, 3x FIBARO FGD212 Dimmer, 1x FIBARO RGBW Controller FGRGBWM-441, 2x FIBARO FGMS001 Motion Sensor and 2x Popp 009006 Plug-in Switch
gizmocuz
Re: Problem with LUA
Post by gizmocuz »
before going the lua way... first try this with the default event system (blockly)
rgroothuis
Post by rgroothuis »
I had a similar problem, and after searching and searching, debugging it turns out that the names are case sensitive and I had one character incorrect. Make sure the device names are 100% correct. Since that moment I always do copy and paste.
RobertH
Post by RobertH »
Got it solved. By stupid mistake I had not set the devices to used, which was something I did when I named them for the other switch. My bad!
