2GIG CT100 Thermostat won't accept Set Point
Posted: Monday 30 November 2015 7:46
Hi all--
I'm running a Raspberry Pi running openzwave-1.3.565, and Domoticz V2.3724. For an interface I use the Aeon Labs Z-Stick 2 (USB). Other than the 2GIG CT100, there's an Aeon Labs smart switch. It's a small network
I am receiving data fine from my thermostat, and can set data values to the Aeon switch (turn on/off) and get data from it. But when I try to send a change of set point to the thermostat, the Domoticz logs show the send command, and the Domoticz web console shows the change. But on the next page reload interval, the Set Point device icon on the Domoticz web console shows no change has occurred. And watching the thermostat panel, no change occurs.
It's almost like the thermostat is in a "read only" mode. the log doesn't show much. sending a value of "17" I get:
Anyone have some suggestions on methods to debug this? much appreciated, thanks!
2015-11-29 22:38:54.935 User: rpiuser initiated a SetPoint command
subtype = SetPoint
Temp = 18.89
2015-11-29 22:38:57.416 (OZW_Zstick) Thermostat (Therm.SP1.HeatPoint)
