Page 1 of 2
Aeon Labs Smart Switch not switching from switches
Posted: Tuesday 24 November 2015 3:33
by Totter
I have a Aeon Labs Aeotec Z-Wave Smart Switch 6, Gen5 switch with and I am using a Gen 5 z-stick.
It wasn't easy but I did get the switch to include, and I can get it to toggle using the zwave control panel.
However, that switch in switches will only show the status of the switch it will not actually toggle the switch. I can only get the switch to toggle through the control panel, and that will update the switch icon in switches, but the switches icon will not actually switch on and off the device, I have to do that in the zwave control panel.
Did I buy a switch that is not fully supported?
Re: Aeon Labs Smart Switch not switching from switches
Posted: Tuesday 24 November 2015 9:07
by gizmocuz
Hi Totter,
this switch is not yet on the market here, and is very new.
I send you a PM, maybe we can make it work
Posted: Saturday 05 December 2015 0:54
by reuscam
I also have several of these switches, and cannot actually toggle them. I am happy to help troubleshoot, if someone wants to get in touch with me via email.
Posted: Friday 15 January 2016 10:12
by Alexsmire
Is there any news on this? I just bought this device and it is the same for me (can toggle from Control Panel but not from Switches) on v2.4192. Looks like OpenZwave supports the device but there is a bug in Domoticz switch command.
Thank you,
Alexandru
Posted: Friday 15 January 2016 15:02
by solid
I have 2 Aeon Labs Smart Switch.
Inclusion is OK on Domoticz, but i can't control them...
Is support team working to include modules in Domoticz?
Posted: Tuesday 19 January 2016 13:49
by ramesses
As Alexsmire wrote: you can't switch it in Domoticz but you CAN switch it in
OpenZWave Control Panel.
Vera has also issue with on/off
see here and
SmartThings Hub too.
Posted: Tuesday 19 January 2016 13:55
by solid
ramesses wrote:As Alexsmire wrote: you can't switch it in Domoticz but you CAN switch it in
see here and
Where is the OpenZwave control panel ?
Posted: Tuesday 19 January 2016 14:13
by solid
solid wrote:ramesses wrote:As Alexsmire wrote: you can't switch it in Domoticz but you CAN switch it in
see here and
I have checked the website link.
I don't see where the code ""luup.call_action('urn:micasaverde-com:serviceId:ZWaveNetwork1','SendData',{Node='16',Data='37 1 255'},1)"" must be implemented in Domoticz.
In Domoticz, this parameter "urn:micasaverde-com" should not be understood.
Have you got some ideas ?
Posted: Tuesday 19 January 2016 18:56
by gizmocuz
Please update to the latest version (beta #4269)
You should now be able to switch the smart switch 6
Posted: Tuesday 19 January 2016 19:08
by solid
gizmocuz wrote:Please update to the latest version (beta #4269)
Yesssss !!
It works !
Thank you
Posted: Thursday 21 January 2016 0:26
by csam
I am using Z-Stick gen5 and Smart Switch 6. Using the version beta #4269 I am able to see the Smart Switch as a switch and not only V, A and W. But I am not able to control it.
When I try to control it from Domoticz, nothing happens, but in the Open Wave Control Panel I am able to switch it on and off.
Have anybody been able to make the Smart Switch 6 work together with the Z-Stick?
Posted: Thursday 21 January 2016 0:33
by csam
After one more restart of Domoticz I can now confirm that it Smart Switch 6 together with Z-Stick works in Domoticz
Posted: Thursday 21 January 2016 8:18
by Alexsmire
Thank you very much for your help!
Posted: Tuesday 26 January 2016 12:07
by Kohen
I have the same problem:
Using synology NAS Domoticz version V2.4198 with Aeon Labs Z-Stick gen5 and the Aeotec Smart Switch 6.
Rebooted my system also rebooted domoticz, I see the smartswitch and all its components in my device list but sending singnal on / off wont work.
Whats wrong? Do I forget something?
Posted: Tuesday 26 January 2016 12:17
by gizmocuz
Kohen wrote:I have the same problem:
Sorry, but compare your version to the version mentioned with the fix ? (#4269)
So that explains why it does not work at your side i think ?
Posted: Tuesday 26 January 2016 12:44
by Kohen
gizmocuz wrote:Kohen wrote:I have the same problem:
Then i have to wait till it is available for synology i guess
Posted: Saturday 13 February 2016 10:23
by rron
Can someone show me his configuration for the smart switch 6? I am still having trouble with it. You should have 4 measurements devices. I only get the voltage working and the rest current and 2 power are not alive.
I,m at the latest beta and i am using the aeon stick zwave +
Posted: Sunday 14 February 2016 15:22
by rron
I have tried setting 101 now on 15. This sould select all the diffent devices. I hope this will work better.
Posted: Monday 15 February 2016 19:28
by Kohen
still waiting for that synology update
Posted: Sunday 21 February 2016 15:18
by rron
Does anyone know if you can use this smart switch measuring on your solarpannels?
