Aeon Labs Smart Switch not switching from switches
- Domoticz version: 2.3530
I have a Aeon Labs Aeotec Z-Wave Smart Switch 6, Gen5 switch with and I am using a Gen 5 z-stick.
It wasn't easy but I did get the switch to include, and I can get it to toggle using the zwave control panel.
However, that switch in switches will only show the status of the switch it will not actually toggle the switch. I can only get the switch to toggle through the control panel, and that will update the switch icon in switches, but the switches icon will not actually switch on and off the device, I have to do that in the zwave control panel.
Did I buy a switch that is not fully supported?
- gizmocuz
Re: Aeon Labs Smart Switch not switching from switches
Hi Totter,
this switch is not yet on the market here, and is very new.
I send you a PM, maybe we can make it work
I also have several of these switches, and cannot actually toggle them. I am happy to help troubleshoot, if someone wants to get in touch with me via email.
Is there any news on this? I just bought this device and it is the same for me (can toggle from Control Panel but not from Switches) on v2.4192. Looks like OpenZwave supports the device but there is a bug in Domoticz switch command.
Thank you,
Alexandru
Thank you,
Alexandru
I have 2 Aeon Labs Smart Switch.
Inclusion is OK on Domoticz, but i can't control them...
Is support team working to include modules in Domoticz?
- Domoticz version: 3.8755
As Alexsmire wrote: you can't switch it in Domoticz but you CAN switch it in OpenZWave Control Panel.
Vera has also issue with on/off see here and SmartThings Hub too.
Domoticz on RaZberry, OZW 1.4-2713
Aeotec MultiSensor 6, Aeotec LED Bulb, Vision ZD2102 Door/Window Sensor, Vision ZP3102 PIR Motion Sensor, D-Link Siren DCH-Z510, Fibaro Smoke Sensor FGSD002, Aeotec Key Fob, Qubino ZMNHDD1 Z-Wave Plus Flush Dimmer
Where is the OpenZwave control panel ?ramesses wrote:As Alexsmire wrote: you can't switch it in Domoticz but you CAN switch it in OpenZWave Control Panel.
I have checked the website link.solid wrote:Where is the OpenZwave control panel ?ramesses wrote:As Alexsmire wrote: you can't switch it in Domoticz but you CAN switch it in OpenZWave Control Panel.
I don't see where the code ""luup.call_action('urn:micasaverde-com:serviceId:ZWaveNetwork1','SendData',{Node='16',Data='37 1 255'},1)"" must be implemented in Domoticz.
In Domoticz, this parameter "urn:micasaverde-com" should not be understood.
Have you got some ideas ?
- gizmocuz
Please update to the latest version (beta #4269)
You should now be able to switch the smart switch 6
Yesssss !!gizmocuz wrote:Please update to the latest version (beta #4269)
It works !
Thank you
I am using Z-Stick gen5 and Smart Switch 6. Using the version beta #4269 I am able to see the Smart Switch as a switch and not only V, A and W. But I am not able to control it.
When I try to control it from Domoticz, nothing happens, but in the Open Wave Control Panel I am able to switch it on and off.
Have anybody been able to make the Smart Switch 6 work together with the Z-Stick?
After one more restart of Domoticz I can now confirm that it Smart Switch 6 together with Z-Stick works in Domoticz
Thank you very much for your help!gizmocuz wrote:Please update to the latest version (beta #4269)
I have the same problem:
Using synology NAS Domoticz version V2.4198 with Aeon Labs Z-Stick gen5 and the Aeotec Smart Switch 6.
Rebooted my system also rebooted domoticz, I see the smartswitch and all its components in my device list but sending singnal on / off wont work.
Whats wrong? Do I forget something?
Synology NAS 412+, Aeotec stick V5, Aeotec recessed door sensor, Aeotec micro double smart switch, Fibaro Dimmer, iPad 2 with own 3d printed wall mount.
- gizmocuz
Sorry, but compare your version to the version mentioned with the fix ? (#4269)Kohen wrote:I have the same problem:
So that explains why it does not work at your side i think ?
Then i have to wait till it is available for synology i guessgizmocuz wrote:Sorry, but compare your version to the version mentioned with the fix ? (#4269)Kohen wrote:I have the same problem:
Can someone show me his configuration for the smart switch 6? I am still having trouble with it. You should have 4 measurements devices. I only get the voltage working and the rest current and 2 power are not alive.
I,m at the latest beta and i am using the aeon stick zwave +
Rpi, RFXcom, klikaan klikuit switch,thermosmart, z-wave, espeasy, smartevse
I have tried setting 101 now on 15. This sould select all the diffent devices. I hope this will work better.
still waiting for that synology update
Does anyone know if you can use this smart switch measuring on your solarpannels?
