Status of an existing door lock?
Posted: Thursday 19 November 2015 10:15
by Awst6000
I already use Kaku Awst-6000 switches to detect if a door/window is open or closed.
Is there perhaps a way to remotely check if a door is locked too?
(But I don't want a new lock. It has to be able to check an existing lock)
Txs.
Re: Status of an existing door lock?
Posted: Monday 08 January 2018 20:24
by jenssen
Awst6000 wrote: Thursday 19 November 2015 10:15
Txs.
-> Any update on this? Looking for the same solution.
Posted: Tuesday 09 January 2018 11:57
by sisaenkov
jenssen wrote: Monday 08 January 2018 20:24
It depends on the type of your door frame.
If it hollow frame with holes for deadbolt you can use some kind of limit switch (I use it):
Also you can use reed switch and little magnet glued on deadbolt:
And the most complex way is to use IR proximity sensor for checking deadbolt position:
