Status of an existing door lock?
Awst6000
Post by Awst6000 »
I already use Kaku Awst-6000 switches to detect if a door/window is open or closed.
Is there perhaps a way to remotely check if a door is locked too?
(But I don't want a new lock. It has to be able to check an existing lock)
Txs.
jenssen
Domoticz version: stable
Re: Status of an existing door lock?
Post by jenssen »
Awst6000 wrote: Thursday 19 November 2015 10:15 Hi,
Txs.
-> Any update on this? Looking for the same solution.
sisaenkov
Domoticz version: 3.8
Post by sisaenkov »
jenssen wrote: Monday 08 January 2018 20:24 -> Any update on this? Looking for the same solution.
It depends on the type of your door frame.
If it hollow frame with holes for deadbolt you can use some kind of limit switch (I use it):
Also you can use reed switch and little magnet glued on deadbolt:
And the most complex way is to use IR proximity sensor for checking deadbolt position:
