Fibaro Switch FGS222 - turns off after 20 seconds
Posted: Friday 13 November 2015 20:40
by Twan
Hi.
I have a FIBARO System FGS222 Double Relay Switch 2x1.5kW.
But I can not get it to be turned on for longer then 20 seconds.
What could cause this behaviour?
grtz,
Twan
Re: Fibaro Switch FGS222 - turns off after 20 seconds
Posted: Saturday 14 November 2015 9:24
by gizmocuz
Hi Twan,
things to check:
- make sure if you edit the switch in domoticz, that you did not specify an off delay value (0=no off delay)
- in the hardware setup of openzwave, select the node and check the configuration, there are settings for an auto off delay here as well:
Parameter No. 3 - Auto off relay after specified time, with the possibility of manual override - immediate Off after button push.
Parameter No. 4 - Auto off for relay 1.
Parameter No. 5 - Auto off for relay 2.
Also make sure there is no more load on the relays then 1.5kW
Posted: Saturday 14 November 2015 9:33
by Twan
Setting Parameter 4 and 5 to 0 did the trick.
Sometimes the descriptions with the many parameters can by quite confusing.
grtz,
Twan
This topic can be closed.
Posted: Saturday 14 November 2015 10:29
by gizmocuz
Its just in the manual ;)
