Fibaro FGK101 not triggering sensor in Domoticz
Posted: Wednesday 11 November 2015 15:19
by rgroothuis
I've a Fibaro FGK101 door sensor and included it into my ZWave network. Inclusion was successful and I can see the device in my Zwave devices list.
- ZWave device list
- Screen Shot 2015-11-11 at 15.16.02.png (160.73 KiB) Viewed 2121 times
As you can see I'm using the "Aeotec Z-Stick Gen5" ZWave controller.
When I open/close the door I do not see any updates in Domoticz, why? Any suggestions why this is the case? The sensor status open the whole time.
- Screen Shot 2015-11-11 at 15.17.52.png (59.18 KiB) Viewed 2121 times
I'm using Domoticz version 2.3530 wint OpenZwave Version: 1.3-523-gb258e9e.
Looking forward to the solution of this problem. Thanks.
Re: Fibaro FGK101 not triggering sensor in Domoticz
Posted: Wednesday 11 November 2015 15:28
by rgroothuis
This is the configuration of the Fibaro door sensor device:
- Fibaro door sensor configuration
- Screen Shot 2015-11-11 at 15.24.38.jpg (385.07 KiB) Viewed 2117 times
Posted: Wednesday 11 November 2015 18:17
by rgroothuis
Some extra info, when I press a couple of time the small button on the Fibaro (so I wake up the device) then it will pass on the status into OpenZwave and Domoticz, then I see the status change. Without waking up the Fibaro doorsendor it will not pass on the status. Any suggestions?
Posted: Sunday 15 November 2015 17:29
by TheoL
I'm experiencing the same problems with Razberry, after updating to the latest stable release. I'm getting a command not send error every time I try to send a command from Domoticz to a zwave device. Did you find a solution?
UPDATE: I just did a fresh install with a new SD card image and everything seems to work fine now. I'll try the database fix on my old images to see if that will fix the problems I'd experienced
Posted: Sunday 15 November 2015 21:24
by rgroothuis
Thanks for sharing this, strange that after a brand new install the problem disappears. I don't want to do a clean install as I then can reconfigure everything. There has to be another solution.
Where do you see that error message? How are you debugging this problem? Where can you find the debug messages?
I can send message to my Fibaro door sensor as I can change to configuration, the problem is that when the magnetic is removed from the door sensor there is not trigger in Openzwave.
Posted: Monday 23 November 2015 15:47
by TheoL
rgroothuis wrote:Thanks for sharing this, strange that after a brand new install the problem disappears. I don't want to do a clean install as I then can reconfigure everything. There has to be another solution.
A bit late, my apologizes. It was a popup in the web GUI.
