Fibaro FGK101 not triggering sensor in Domoticz
rgroothuis
Post by rgroothuis »
I've a Fibaro FGK101 door sensor and included it into my ZWave network. Inclusion was successful and I can see the device in my Zwave devices list.
ZWave device list
ZWave device list
Screen Shot 2015-11-11 at 15.16.02.png (160.73 KiB) Viewed 2119 times
As you can see I'm using the "Aeotec Z-Stick Gen5" ZWave controller.
When I open/close the door I do not see any updates in Domoticz, why? Any suggestions why this is the case? The sensor status open the whole time.
Screen Shot 2015-11-11 at 15.17.52.png (59.18 KiB) Viewed 2119 times
I'm using Domoticz version 2.3530 wint OpenZwave Version: 1.3-523-gb258e9e.
Looking forward to the solution of this problem. Thanks.
rgroothuis
Re: Fibaro FGK101 not triggering sensor in Domoticz
This is the configuration of the Fibaro door sensor device:
Fibaro door sensor configuration
Screen Shot 2015-11-11 at 15.24.38.jpg (385.07 KiB) Viewed 2115 times
rgroothuis
Some extra info, when I press a couple of time the small button on the Fibaro (so I wake up the device) then it will pass on the status into OpenZwave and Domoticz, then I see the status change. Without waking up the Fibaro doorsendor it will not pass on the status. Any suggestions?
TheoL
Domoticz version: 2024.7
Post by TheoL »
I'm experiencing the same problems with Razberry, after updating to the latest stable release. I'm getting a command not send error every time I try to send a command from Domoticz to a zwave device. Did you find a solution?
UPDATE: I just did a fresh install with a new SD card image and everything seems to work fine now. I'll try the database fix on my old images to see if that will fix the problems I'd experienced
rgroothuis
Thanks for sharing this, strange that after a brand new install the problem disappears. I don't want to do a clean install as I then can reconfigure everything. There has to be another solution.
Where do you see that error message? How are you debugging this problem? Where can you find the debug messages?
I can send message to my Fibaro door sensor as I can change to configuration, the problem is that when the magnetic is removed from the door sensor there is not trigger in Openzwave.
TheoL
Post by TheoL »
rgroothuis wrote:Thanks for sharing this, strange that after a brand new install the problem disappears. I don't want to do a clean install as I then can reconfigure everything. There has to be another solution.
A bit late, my apologizes. It was a popup in the web GUI.
