How send notification few minutes after events_
Posted: Tuesday 10 November 2015 23:30
by scatman
I need help you!
Can I ask for example events in wicht I send notification in few minutes after events?
THX
Re: How send notification few minutes after events_
Posted: Wednesday 11 November 2015 7:25
by jannl
Easiest way (I think) would be start a bash script, wait the desired time and sens the notification via json.
Posted: Wednesday 11 November 2015 8:27
by Egregius
To be clear: if an event (motion, contact whatever) occurs, you want to wait several minutes before sending the notification? Does the event still need to be 'actual' at that point?
I think you need to explain a bit more the situation. I want notification to be sent asap, before burglars might cut the power.
Posted: Wednesday 11 November 2015 8:48
by scatman
Egregius wrote:To be clear: if an event (motion, contact whatever) occurs, you want to wait several minutes before sending the notification? Does the event still need to be 'actual' at that point?
Yes, if an event (motion, contact whatever) occurs, I want to wait several minutes before sending the notification! For example when my door garage stay open for 5 minutes I want get notification of them.
Posted: Wednesday 11 November 2015 8:51
by scatman
jannl wrote:Easiest way (I think) would be start a bash script, wait the desired time and sens the notification via json.
Maybe but I don't know how I can do :( Can you me introduce step by step?
Posted: Wednesday 11 November 2015 8:53
by jannl
I would have to google a lot as well, nothing I did yet.
But I think there example scripts for what you want in wiki
Posted: Wednesday 11 November 2015 9:13
by Jan Jansen
You can create an virtual switch (for example named notification). Set on delay of this switch as you wish and off delay at for example 5 sec.
Blockly
if ... (trigger device) is on
do set notification on
if notification is on
do sent notification
Posted: Wednesday 11 November 2015 10:12
by Egregius
scatman wrote:
Egregius wrote:For example when my door garage stay open for 5 minutes I want get notification of them.
Oh, that way. I have that in my PHP script :)
if($Spoort!='Closed') {if(xcache_get('alertpoort')<$time-900&&$STpoort<$time-900) {$msg='Poort Open sinds '.strftime("%H:%M:%S", $STpoort);xcache_set('alertpoort',$time);telegram($msg);}}
This sents a telegram every 900 seconds if the port is open for more than 900 seconds.
Posted: Wednesday 11 November 2015 12:45
by scatman
Jan Jansen wrote:You can create an virtual switch (for example named notification). Set on delay of this switch as you wish and off delay at for example 5 sec.
Blockly
THX I used this advice.
