How send notification few minutes after events_
scatman
Domoticz version: 2.2563
Post by scatman »
I need help you!
Can I ask for example events in wicht I send notification in few minutes after events?
THX
jannl
Domoticz version: 2026.1.x
Re: How send notification few minutes after events_
Post by jannl »
Easiest way (I think) would be start a bash script, wait the desired time and sens the notification via json.
Egregius
Domoticz version: v2024.7
Post by Egregius »
To be clear: if an event (motion, contact whatever) occurs, you want to wait several minutes before sending the notification? Does the event still need to be 'actual' at that point?
I think you need to explain a bit more the situation. I want notification to be sent asap, before burglars might cut the power.
scatman
Post by scatman »
Egregius wrote:To be clear: if an event (motion, contact whatever) occurs, you want to wait several minutes before sending the notification? Does the event still need to be 'actual' at that point?
Yes, if an event (motion, contact whatever) occurs, I want to wait several minutes before sending the notification! For example when my door garage stay open for 5 minutes I want get notification of them.
scatman
Post by scatman »
jannl wrote:Easiest way (I think) would be start a bash script, wait the desired time and sens the notification via json.
Maybe but I don't know how I can do :( Can you me introduce step by step?
jannl
Post by jannl »
I would have to google a lot as well, nothing I did yet.
But I think there example scripts for what you want in wiki
Jan Jansen
Domoticz version: Stable
Post by Jan Jansen »
You can create an virtual switch (for example named notification). Set on delay of this switch as you wish and off delay at for example 5 sec.
Blockly
if ... (trigger device) is on
do set notification on
if notification is on
do sent notification
Egregius
Post by Egregius »
scatman wrote:
Egregius wrote:For example when my door garage stay open for 5 minutes I want get notification of them.
Oh, that way. I have that in my PHP script :)
if($Spoort!='Closed') {if(xcache_get('alertpoort')<$time-900&&$STpoort<$time-900) {$msg='Poort Open sinds '.strftime("%H:%M:%S", $STpoort);xcache_set('alertpoort',$time);telegram($msg);}}
This sents a telegram every 900 seconds if the port is open for more than 900 seconds.
scatman
Post by scatman »
Jan Jansen wrote:You can create an virtual switch (for example named notification). Set on delay of this switch as you wish and off delay at for example 5 sec.
Blockly
THX I used this advice.
