How to import data from php script for a counter
btw8
Post by btw8 »
Hello Community,
i'm new to domoticz and not sure if this is the right place for my question.
Domoticz is running here on a Synology DS-214. Everything is perfect so far but now i wonder how to get data from variables in php script that is running on the same machine into domoticz as a counter. I know Javascript and a little bit PHP. So i made a script to read out data from my solar inverter (Kostal Piko 4.2), see below.
In domoticz i set up a dummy device with a virtual sensor. And now? Is it possible to import the output from my script?
<?php
    /* ########## DATA KOSTAL ########## */
        $url = "192.168.11.99";
        $username = "user";
        $password = "password";
        $ch = curl_init();
        curl_setopt($ch, CURLOPT_URL, $url);
        curl_setopt($ch, CURLOPT_RETURNTRANSFER, true);
        curl_setopt($ch, CURLOPT_USERPWD, "$username:$password");
        curl_setopt($ch, CURLOPT_HTTPAUTH, CURLAUTH_BASIC);
        $output = curl_exec($ch);
        $info = curl_getinfo($ch);
        curl_close($ch);
        $pos1 = strpos($output,"aktuell</td>");
        $pos2 = strpos($output,"</td>",$pos1+20);
        $data = substr($output,($pos1+65),$pos2-$pos1-65);
    /* # WERT ERTRAG # */
        $ertrag = (float) $data;
        $pos1 = strpos($output,"Gesamtenergie</td>");
        $pos2 = strpos($output,"</td>",$pos1+30);
    /* # WERT GESAMTERTRAG # */
        $gesamtertrag = substr($output,($pos1+70),$pos2-$pos1-70);
        $pos1 = strpos($output,"Tagesenergie</td>");
    /* # WERT TAGESERTRAG # */
        $tagesertrag = substr($output,($pos1+70),$pos2-$pos1-70);
echo($ertrag);
echo($tagesertrag);
echo($gesamtertrag);
regards, Oliver
Synology DS-918+, RFXtrx433E, Philips Hue
stlaha2007
Re: How to import data from php script for a counter
Post by stlaha2007 »
Hi Oliver,
Havent tried out php to push data into domoticz. However the subforums contain several examples...
I would recommend to look at the domoticz.com/wiki/json api....
There are some examples how to create and update virtual devices.
For example iḿ using RFXmeter with gas and water to import the meter readings from file.
According to your story your better use rfxmeter with electricity or the (P1) power and counter.
I created the virtualsensors with bash commandline tools directly with the json-api.
Also using this to push the data into domoticz.
Eg. Push 120Watt And Counter 123456 into an Electricity Meter VirtualDevice
curl -s "http://domoticz.ipadd.ressImageortnumber/json.htm?type=command&param=udevice&idx=VirtualDeviceIDX&svalue=120;123456"
Grtz,
Stephan
Sent from my K00C using Tapatalk
btw8
Post by btw8 »
Thank you Stephan for pointing me in the right direction.
The following script works for pushing the value of actual power to a virtual device.
Greetings, Oliver.
<?php
        $username = "user";
        $ch = curl_init();
        curl_close($ch);
        $actualpower = (float) $data;
/* ########## PUSH DATA TO DOMOTICZ ########## */
$url = '192.168.11.90:8084/json.htm?';
$ch = curl_init();
curl_setopt($ch, CURLOPT_URL,$url.http_build_query(
		array(
			'type' => 'command',
			'param' => 'udevice',
			'idx' => '24',
			'svalue' => $actualpower
curl_exec ($ch);
curl_close ($ch);
