Page 1 of 2
A STOP button
Posted: Tuesday 27 October 2015 22:57
by caape
Hello
Is it possible to have a STOP button on the switch BLINDS PERCENTAGE order to stop the movement at any time ?
Thank you
Caape
Re: A STOP button
Posted: Wednesday 28 October 2015 9:27
by gizmocuz
What type of hardware are you using with this switch?
Re: A STOP button
Posted: Wednesday 28 October 2015 10:01
by caape
It's for a window shutter.
Re: A STOP button
Posted: Wednesday 28 October 2015 11:13
by gizmocuz
i believe that, what hardware device do you use in domoticz for this ?
Openzwave, dummy, rfxcom, ....?
Re: A STOP button
Posted: Wednesday 28 October 2015 11:41
by caape
It is a personal controller that uses the protocol MySensors.
I have two push buttons on the wall , one for up and one for down .
In Domoticz , I have two widgets that have been created, a percentage blinds and blinds , but I would like one with the percentage and stop button in addition to the up and down buttons.
Sorry for my English , I am French and I have a little trouble.
Thx
Re: A STOP button
Posted: Wednesday 28 October 2015 19:56
by gizmocuz
no problems....
yes you should use the normal blind, this has the stop button....
i have first to test (could take some time) how to 'stop' the fibaro roller shutter if i want to patch this,
at the moment there is no implementation for 'stop' for this kind of sensor
Re: A STOP button
Posted: Wednesday 28 October 2015 20:07
by jvdz
I have a couple of Fibaro shutter switches ( FGRM222) and have these also linked to a remote control (ZME_RC2).
I can stop the screens when they are closing by doing a long press on Off button (Led starts flickering). The short press (solid light) just reverses the direction.
Hope that helps,
Jos
Re: A STOP button
Posted: Thursday 29 October 2015 10:06
by caape
OK
thanks you
Re: A STOP button
Posted: Saturday 07 November 2015 10:34
by gizmocuz
jvdz wrote:I have a couple of Fibaro shutter switches ( FGRM222) and have these also linked to a remote control (ZME_RC2).
Hope that helps,
Jos
Is it possible to log (openzwave debug log) what command is send when you long press the off button?
This works for both directions ?
Re: A STOP button
Posted: Sunday 15 November 2015 21:25
by jvdz
Sorry, but I missed this request last week.
Let me know when you still would like me to restart Domoticz in debug mode and capture these key presses.
Jos
Re: A STOP button
Posted: Monday 16 November 2015 7:32
by gizmocuz
Hi Jos,
If you could do this, that would be great...
Re: A STOP button
Posted: Monday 16 November 2015 9:51
by jvdz
This is the result of first a short press on the Left 1 button to start the down motion:
2015-11-16 09:42:29.883 Detail,
2015-11-16 09:42:29.875 Detail, Node016,   Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x10, 0x06, 0x31, 0x05, 0x04, 0x22, 0x05, 0x10, 0xe6
2015-11-16 09:42:29.883 Info, Node016, Received SensorMultiLevel report from node 16, instance 1, Power: value=129.6W
2015-11-16 09:42:29.883 Detail, Node016, Refreshed Value: old value=0.0, new value=129.6, type=decimal
2015-11-16 09:42:29.883 Detail, Node016, Changes to this value are not verified
2015-11-16 09:42:29.883 Detail, Node016, Notification: ValueChanged
.. and then I press the right 1 button a little longer and then release it. it will stop the down motion after release:
2015-11-16 09:42:35.626 Detail, Node016,   Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x10, 0x03, 0x26, 0x03, 0x16, 0xd2
2015-11-16 09:42:35.626 Info, Node016, Received SwitchMultiLevel report: level=22
2015-11-16 09:42:35.626 Detail, Node016, Refreshed Value: old value=0, new value=22, type=byte
2015-11-16 09:42:35.627 Detail, Node016, Changes to this value are not verified
2015-11-16 09:42:35.627 Detail, Node016, Notification: ValueChanged
2015-11-16 09:42:35.768 Detail, Node016,   Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x10, 0x06, 0x31, 0x05, 0x04, 0x22, 0x00, 0x00, 0xf3
2015-11-16 09:42:35.768 Info, Node016, Received SensorMultiLevel report from node 16, instance 1, Power: value=0.0W
2015-11-16 09:42:35.768 Detail, Node016, Refreshed Value: old value=129.6, new value=0.0, type=decimal
2015-11-16 09:42:35.769 Detail, Node016, Changes to this value are not verified
2015-11-16 09:42:35.769 Detail, Node016, Notification: ValueChanged
Same steps but now the opposite way:
2015-11-16 09:43:02.670 Detail, Node016,   Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x10, 0x06, 0x31, 0x05, 0x04, 0x22, 0x05, 0x0f, 0xf9
2015-11-16 09:43:02.671 Info, Node016, Received SensorMultiLevel report from node 16, instance 1, Power: value=129.5W
2015-11-16 09:43:02.671 Detail, Node016, Refreshed Value: old value=0.0, new value=129.5, type=decimal
2015-11-16 09:43:02.671 Detail, Node016, Changes to this value are not verified
2015-11-16 09:43:02.671 Detail, Node016, Notification: ValueChanged
2015-11-16 09:43:05.644 Detail, Node016,   Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x10, 0x03, 0x26, 0x03, 0x0b, 0xcf
2015-11-16 09:43:05.645 Detail,
2015-11-16 09:43:05.645 Info, Node016, Received SwitchMultiLevel report: level=11
2015-11-16 09:43:05.645 Detail, Node016, Refreshed Value: old value=22, new value=11, type=byte
2015-11-16 09:43:05.645 Detail, Node016, Changes to this value are not verified
2015-11-16 09:43:05.645 Detail, Node016, Notification: ValueChanged
2015-11-16 09:43:05.823 Detail, Node016,   Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x10, 0x06, 0x31, 0x05, 0x04, 0x22, 0x00, 0x00, 0xf3
2015-11-16 09:43:05.824 Detail,
2015-11-16 09:43:05.824 Info, Node016, Received SensorMultiLevel report from node 16, instance 1, Power: value=0.0W
2015-11-16 09:43:05.824 Detail, Node016, Refreshed Value: old value=129.5, new value=0.0, type=decimal
2015-11-16 09:43:05.824 Detail, Node016, Changes to this value are not verified
2015-11-16 09:43:05.824 Detail, Node016, Notification: ValueChanged
The screen is associated with the remote control so put the devicenumber in group 2 to associate it with button 1.
Let me know when you need more info.
Jos
Re: A STOP button
Posted: Sunday 06 December 2015 14:51
by gizmocuz
@jvdz, i cant find a command 'stop' in your log....
Re: A STOP button
Posted: Sunday 06 December 2015 15:19
by jvdz
There is no real stop button available on the remote and I described the process I use to stop the screens earlier:
The log shows these keypresses. :)
Anythings else I can do to assist?
Jos
Re: A STOP button
Posted: Sunday 06 December 2015 15:21
by gizmocuz
well technically it does not show anything
no send command or anything
i think this is because you assigned the remote directly to the roller shutter, and this bypasses everything (domoticz/openzwave)
Re: A STOP button
Posted: Sunday 06 December 2015 15:55
by jvdz
mmm.. of course, sorry about that.
I have added 1 to the group on the remote for the screen and now received this:
Start down motion
2015-12-06 15:45:51.079 Detail, Node016,   Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x10, 0x06, 0x31, 0x05, 0x04, 0x22, 0x05, 0x12, 0xe4
2015-12-06 15:45:51.080 Detail,
2015-12-06 15:45:51.080 Info, Node016, Received SensorMultiLevel report from node 16, instance 1, Power: value=129.8W
2015-12-06 15:45:51.080 Detail, Node016, Refreshed Value: old value=0.0, new value=129.8, type=decimal
2015-12-06 15:45:51.081 Detail, Node016, Changes to this value are not verified
2015-12-06 15:45:51.081 Detail, Node016, Notification: ValueChanged
Stop down motion :
2015-12-06 15:45:57.521 Detail, Node016,   Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x10, 0x03, 0x26, 0x03, 0x18, 0xdc
2015-12-06 15:45:57.522 Detail,
2015-12-06 15:45:57.522 Info, Node016, Received SwitchMultiLevel report: level=24
2015-12-06 15:45:57.522 Detail, Node016, Refreshed Value: old value=0, new value=24, type=byte
2015-12-06 15:45:57.522 Detail, Node016, Changes to this value are not verified
2015-12-06 15:45:57.522 Detail, Node016, Notification: ValueChanged
2015-12-06 15:45:57.680 Detail, Node016,   Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x10, 0x06, 0x31, 0x05, 0x04, 0x22, 0x00, 0x00, 0xf3
2015-12-06 15:45:57.681 Detail,
2015-12-06 15:45:57.681 Info, Node016, Received SensorMultiLevel report from node 16, instance 1, Power: value=0.0W
2015-12-06 15:45:57.681 Detail, Node016, Refreshed Value: old value=129.8, new value=0.0, type=decimal
2015-12-06 15:45:57.681 Detail, Node016, Changes to this value are not verified
2015-12-06 15:45:57.681 Detail, Node016, Notification: ValueChanged
Does that help?
Jos
Re: A STOP button
Posted: Sunday 06 December 2015 16:04
by jvdz
Duh ... You need the commands from the remote, not the Screen.
Start:
2015-12-06 15:45:49.952 Detail, Node042,   Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x2a, 0x03, 0x20, 0x01, 0xff, 0x05
2015-12-06 15:45:49.952 Info, Node042, Received Basic set from node 42: level=255.  Sending event notification.
2015-12-06 15:45:49.952 Detail, Node042, Notification: NodeEvent
Stop
2015-12-06 15:45:55.117 Detail, Node042,   Received: 0x01, 0x0a, 0x00, 0x04, 0x00, 0x2a, 0x04, 0x26, 0x04, 0x60, 0x00, 0x9d
2015-12-06 15:45:56.513 Detail, Node042,   Received: 0x01, 0x08, 0x00, 0x04, 0x00, 0x2a, 0x02, 0x26, 0x05, 0xf8
2015-12-06 15:45:56.514 Detail,
Better?
Jos
Re: A STOP button
Posted: Monday 07 December 2015 9:27
by gizmocuz
Also here when issuing the 'stop' command i only see 2 received logs, no set's
Re: A STOP button
Posted: Monday 07 December 2015 10:21
by jvdz
gizmocuz wrote:Also here when issuing the 'stop' command i only see 2 received logs, no set's
Isn't this expected since the command is send from the remove to both the Screen (16) and the Controller(1)?
This is what I thought was happening but could be totally wrong :?
This is the line when I press the Left-button briefly which Starts the down action:2015-12-06 15:45:49.952 Detail, Node042, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x2a, 0x03, 0x20, 0x01, 0xff, 0x05
Which is translated to Set the level to 255.
I believe that this line is send when I press the Right-button down: 2015-12-06 15:45:55.117 Detail, Node042, Received: 0x01, 0x0a, 0x00, 0x04, 0x00, 0x2a, 0x04, 0x26, 0x04, 0x60, 0x00, 0x9d
and this is send when the button is release at which time the screen stops: 2015-12-06 15:45:56.513 Detail, Node042, Received: 0x01, 0x08, 0x00, 0x04, 0x00, 0x2a, 0x02, 0x26, 0x05, 0xf8
I am not that familiar with all of this yet, so would need some pointers what is to be expected.
Cheers
Jos
Re: A STOP button
Posted: Monday 07 December 2015 19:23
by jvdz
Just though of another thing I could try so went into the ZWAVE controlpanel to have a play.
I started the down motion by Setting the Switch field to "On". Then when I click on either "Open"/"Close"/"Inc"/"Dec" the down motion will stop.
Didn't capture the Debug ZWAVE command yet, so let me know in case that would be helpful to have as well.
Jos
