Is anyone in the UK monitoring gas usage? If so what hardware are you using to do it?
Have you seen the picture from threadstarter. Seems to me he doesn't have a turning wheel.ThinkPad wrote:Have a look at the MySensors project.
For the reflective mirror in the counting reel, a TCRT5000 / CNY70 photosensor can probably be used. But your gasmeter might also have a little magnet in the counter reel, maybe you can pickup this signal with a so called 'reed contact'.
Thanks for the reply.. eek! £70 is much more than I was thinking tho. Need to do more thinkingticktime wrote:This might work for you. But at this point, there is no way to extract data.
http://www.amazon.co.uk/dp/B00YNCJB3S/r ... 91PMQ1DGJM
Interesting approach. I had a friend thinking about this idea as well but seemed like too much workstlaha2007 wrote:Hi there,
Im not from UK but Netherlands. Here part of the household have smartmeters. Unfortunately mine will get one scheduled for end of 2017. So i have almost the same start, an analog meter with digits.
What i have done is read the number with an IPcam ....
This might be the way to go but to be honest it might be a bit beyond me. I'll need to do a bit of reading.ThinkPad wrote:Have a look at the MySensors project, by building something like this: http://www.mysensors.org/build/pulse_water you can probably get it into Domoticz.
There is already support for MySensors in Domoticz. Don't forget that, apart from the sensor node, you also need a MySensors gateway to receive the data from the nodes in Domoticz.
Thanks!thebeetleuk wrote: Interesting approach. I had a friend thinking about this idea as well but seemed like too much workIf I did go down this route I think I would need an IP camera that had power over ethernet due to the position of the gas meter. Good luck with your testing and let us know how you get on
Maybe mine will have some sort of. Need to investigate further.markk wrote:I've got one of these meters and found that you don't need to mess about with pulses or magnets on wheels. Mine has an RJ11 port under the last set of numbers. I connected an old telephone cable to this and to a modified reed switch and got an open signal every time the numbers moved but didn't have the know how to devise something to record and measure it. Someone with a bit of savvy should be able to do this easily enough.
Looks like you have to have the loop electricity monitor (45GBP) for the gas monitor to work so 75GBP totalamz4u2nv wrote:for those in the uk... looked up the loop gas energy meter - its £30 b&q.
http://www.diy.com/departments/loop-gas ... 12154615:s
I think its possible to write a script to scrape the results from the loop website and add it to domoticz.
