Use sunset and sunrise time in lua
Posted: Sunday 25 October 2015 7:58
by salvation
I was wondering how I could use the sunset and sunrise time in LUA? I've found the timeofday variable daytime, nighttime and sunsetinminutes. But I'm looking to use the time. Just like the option in blocky or the time returned in the json call /json.htm?type=command&param=getSunRiseSet
   "ServerTime" : "Sep 30 2013 17:15:21",
   "Sunrise" : "07:38:00",
   "Sunset" : "19:16:00",
   "status" : "OK",
   "title" : "getSunRiseSet"
Anybody know how to achieve this?
Re: Use sunset and sunrise time in lua
Posted: Sunday 25 October 2015 10:03
by jvdz
This is an example which will run at sunset - 10 minutes:
	-- get current time
	timenow = os.date("*t")
	minutesnow = timenow.min + timenow.hour * 60
	-- test for sunset - 10 minutes
	if (minutesnow == timeofday['SunsetInMinutes'] - 10) then
		-- do something
Jos
Posted: Tuesday 27 October 2015 19:39
by Whatsek
Thank you for this nice example!
Posted: Sunday 01 November 2015 19:31
by salvation
Tnx jvzd, I already found that option. But that was not what I was looking for, though the results are the same.
Posted: Friday 02 September 2016 21:43
by marigo
jvdz wrote:This is an example which will run at sunset - 10 minutes:
	-- get current time
		-- do something
Jos
If I use this lua script and send an e-mail when it's 10 minutes to sunset then I will get 8 e-mails
commandArray['SendEmail']='Sunset-test#Het is 10 minuten voor zonsondergang#[email protected]'
What am I doing wrong?
Posted: Friday 02 September 2016 22:24
by jvdz
How is the script ran?
Is in an script in the internal editor and did you change the dropdownbox below LUA to Time?
Jos
Posted: Friday 02 September 2016 22:25
by bizziebis
Save it as a Time script, not as a Device script
Posted: Sunday 04 September 2016 16:09
by marigo
Hmmm, I think that's were I went wrong. I have changed the script name from "device" to "time".
In about a few hours I can update this tread and let you know if it worked. :)
EDIT: it works perfect now! Thank you all for the replies.
script name: script_time_sunset-test.lua
   -- get current time
