Use sunset and sunrise time in lua
salvation
Post by salvation »
I was wondering how I could use the sunset and sunrise time in LUA? I've found the timeofday variable daytime, nighttime and sunsetinminutes. But I'm looking to use the time. Just like the option in blocky or the time returned in the json call /json.htm?type=command&param=getSunRiseSet
   "ServerTime" : "Sep 30 2013 17:15:21",
   "Sunrise" : "07:38:00",
   "Sunset" : "19:16:00",
   "status" : "OK",
   "title" : "getSunRiseSet"
Anybody know how to achieve this?
jvdz
Domoticz version: 4.107
Re: Use sunset and sunrise time in lua
Post by jvdz »
This is an example which will run at sunset - 10 minutes:
	-- get current time
	timenow = os.date("*t")
	minutesnow = timenow.min + timenow.hour * 60
	-- test for sunset - 10 minutes
	if (minutesnow == timeofday['SunsetInMinutes'] - 10) then
		-- do something
Jos
Whatsek
Domoticz version: Latest B
Post by Whatsek »
Thank you for this nice example!
salvation
Post by salvation »
Tnx jvzd, I already found that option. But that was not what I was looking for, though the results are the same.
marigo
Post by marigo »
jvdz wrote:This is an example which will run at sunset - 10 minutes:
	-- get current time
		-- do something
Jos
If I use this lua script and send an e-mail when it's 10 minutes to sunset then I will get 8 e-mails
commandArray['SendEmail']='Sunset-test#Het is 10 minuten voor zonsondergang#[email protected]'
What am I doing wrong?
jvdz
Post by jvdz »
How is the script ran?
Is in an script in the internal editor and did you change the dropdownbox below LUA to Time?
Jos
bizziebis
Domoticz version: 3.8805
Post by bizziebis »
Save it as a Time script, not as a Device script
marigo
Post by marigo »
Hmmm, I think that's were I went wrong. I have changed the script name from "device" to "time".
In about a few hours I can update this tread and let you know if it worked. :)
EDIT: it works perfect now! Thank you all for the replies.
script name: script_time_sunset-test.lua
   -- get current time
