I cannot seem to get my Schlage lock added properly. I am running Domoticz in unRaid on a server VM. Everything works flawlessly, however I cannot get my lock to add.
Since I cannot move my server to my door, I unplug my stick and add devices with it, then replug and reboot Domoticz. Has worked for light switches, home energy monitor, smart plugs, and others. I cannot get it to work for my lock.
I go through the adding process on the lock:
- 6 digit code
- 0
- Wait for pair
Both the stick and lock blink rapidly, but then the stick returns to a normal blink, and then stops blinking after about a minute. My lock continues to blink orange for another minute, then I get a red X.
Interestingly enough, after going through this a few times, I gave up and plugged back into server. Domoticz has a new Z-wave device, unknown, and a new device, labeled as "Light 2" type.
Any way to get this properly added?
Schlage Lock + Z-Stick S2
- Domoticz version: 3.5196
Re: Schlage Lock + Z-Stick S2
Did you ever have any luck with this?
For secure devices you want to add it via the OZW CP, there is a drop down for Add Secure Node, then do the button+code+0, it should then pair correctly.
Im actually running in a problem now with it not reporting back. It will change the state of the door but Domoticz wont update when its changed by hand.
[ Domoticz 3.5196 | Win10 | AeoTec Z-Stick Gen5 ]
i have exactly the same issue, unresolved.
can you elaborate on the "add secure" functionality? i see that in the z-stick control panel in domo, but the add secure doesn't seem to work - perhaps because the stick is far from the lock when i do this? i've always added devices by simply unplugging the stick and walking over to the device... how does it work in an "add secure" fashion?
thanks for any assistance.
hey @dzaret,
https://github.com/OpenZWave/open-zwave ... ces-to-OZW
there are the details, but the short of it is you need to define a security key in the ozw config and then securely add it (the include secure on the CP)
its been a while since i messed with it, but if you've added it insecurely make sure you do a factory reset, maybe more than once, i had some weird things going on when i tried to switch it over to secure..
