automatic garagedoor opener/closer
Posted: Saturday 02 November 2013 11:05
by remb0
I would buy a garagedoor with a motorised system to open/close.
But I like to also see it in domoticz. At the sites of the doors I can't see protocols/frequenties.
does somebody have experiences or a dutch seller adress that have a system that is compatible?
Re: automatic garagedoor opener/closer
Posted: Saturday 02 November 2013 11:15
by gizmocuz
Would this work with a system used for blinds?
Posted: Saturday 02 November 2013 11:26
by pepijn
Most doors can be operated using a KAKU ASUN650.
Posted: Saturday 02 November 2013 11:38
by elythomaslumber
I'm using a very old Bosch system and have removed the 27MHz receiver 2 years ago since the transmitter was as big as a cigarette package
Most, maybe all garage door opener have an additional external potential free "input" for a separate switch. So I used a 433MHz remote switch from Intertechno whis an integrated timer (2sek).
Works great with a
http://www.intertechno.at/produkte/empf ... -1000.html and those transmitters
http://www.intertechno.at/produkte/send ... K-200.html or this
http://www.intertechno.at/produkte/send ... TKL-2.html.
Finally 've installed additionally a second Raspy with Domoticz as a slave via power LAn connector. Via a relay connected on one GPIO pin via a simple transistor switch I can control the door opener now also from remote using also the external input.
Normally you need only a push button function for openening ans closing. So first push is "open", second push is "close",...
Regrads
Hardy
http://2.bp.blogspot.com/-8XPDmQ79eLc/U ... ircuit.png
Posted: Sunday 10 November 2013 16:42
by gbCambridge
Not quite... there is a safety feature.
First push is open. If you push again and the door is still moving then it stops. If you now push again it will go back to closing. I assume this logic is outside of your control so it should still work, but it does need checking from the safety point of view
George
Posted: Sunday 10 November 2013 17:22
by elythomaslumber
You are right,...but I've pre-installed two connectors to my GPIO pins. Both are set to "IN" using wiringPi.
Next is to install 2 sensors (contacts) showing me the postion "Full yopen", "Fully closed" or "Partly Open".
Currently I try to show the position using the dimmer symbol but couldn't get it working until today. I'm trying to use the slider of the dimmer symbol...
If I couldn't get it to work I will use 2 separate "contact" symbols.
Currently I have not installed the contacts due to bad weather conditions
Hardy
- garage.jpg (36.61 KiB) Viewed 3592 times
Posted: Wednesday 25 November 2015 12:38
by RonCohen
Hi. You can use an automation to remotely monitor whether your garage door is open or closed and to remotely operate the garage door opener.
