Hi, I would like flash my Hue lights in a certain color when a sensor reached a defined level (for instance CO-2 level). After the flashing i'd like to return the Hue status from before flashing.
In order to do this I have to save the Hue state; via JSON I can retrieve the dim-level, XOffset and YOffset. Next step would be a series of "set" commands to do the flashing and ending with the original state. Setting the dim-level is possible via JSON but is there any way to set the colors (XOffset and YOffset)?
Set RGBW values via script (JSON)?
- Mooseknuckle
Re: Set RGBW values via script (JSON)?
Allthough it's not exactly what you want there is already some native Hue support for this:
http://www.developers.meethue.com/docum ... e-concepts
You can create a bash script with something like this:
This will make 1 light blink in the last selected color for that light.
#!/bin/bash
curl -H "Accept: application/json" -X PUT --data '{"alert":"lselect"}' http://<Bridge ip address>/api/<HUE_api_user>/lights/1/state
RPI 3, Philips Hue,Toon Thermostat, Harmony Smart Control, Yeelights
Mysensors wifi gateway + sensors, RFXtrx433E, Kaku stuff, Xiaomi gateway + sensors
Domoticz controlled DIY ambilight, Selectplus chime, Mi-light led controller
tomson
- Domoticz version: Latest
I was looking for the same. It is described here: viewtopic.php?f=4&t=5302&hilit=json+rgbw
Although the JSON command results in an error
it does work fine.
"status" : "ERR"
}Who is online
