I am trying to install the serial port monitor for node-red that is part of the domoticz package.
https://www.npmjs.com/package/node-red-node-serialport
Not too sure where to install it from on this system as per the guide in the link.
Run the following command in the root directory of your Node-RED install, usually this is ~/.node-red .
sudo npm install -g --unsafe-perm node-red-node-serialport
Would also like to know how to manually stop and start node-red in the domoticz install
Any help appreciated
Node-Red Serial Monitor Install
wildfire
Re: Node-Red Serial Monitor Install
this might be to late but to start and stop node red u use
sudo /etc/init.d/nodered start/stop/restart
