Page 1 of 2
HOME COMFORT modules (or SMART HOME / IDK) ECR-100
Posted: Monday 07 September 2015 20:51
by sebitop
Hi guys
does someone managed to have the ECR-100 module working with domoticz ?
here is the link
http://www.home-confort.net/fr/content/ ... -chauffage
I tried different signals but i don't know if i'm doing it well.
thank you in advance for your help
Re: home confortl / smart home/ ECR-100
Posted: Monday 07 September 2015 21:25
by ThinkPad
Looks exactly the same as: http://www.klikaanklikuit.nl/shop/nl/in ... -acm-1000/
Use type 'AC', use random code and when unit is in paring mode, click 'Test' button in Domoticz.
Let me know if it works
Posted: Tuesday 08 September 2015 8:47
by sebitop
it looks but it's not exactly the same, mine as a green led and seems to refuse to work with AC
I will try again this evening and keep you posted, could be usefull to know.
Posted: Tuesday 08 September 2015 8:56
by Stuntteam
ThinkPad wrote:Looks exactly the same as: http://www.klikaanklikuit.nl/shop/nl/in ... -acm-1000/
I doubt it is the same.
The RFLink Gateway supports the Home Confort Smart Home products (among others the TEL-010 remote control) and the protocol is totally different.
Posted: Tuesday 08 September 2015 17:52
by sebitop
i tried by it dosen't work ...
Posted: Tuesday 22 September 2015 15:46
by sebitop
I've been in contact with the RFXCOM team to implement this protocol on the RFXCOM module.
I just tested it with RFXMGR and it works perfectly i'm able to control these new modules
so now just nee to be implemented in Domoticz.
I posted a modification request in the tracker.
et me know if you need any help to test it.
cheers
sebastien
Re: HOME COMFORT modules (or SMART HOME / IDK) ECR-100
Posted: Monday 28 September 2015 23:33
by sebitop
more info on HOME COMFORT modules : http://www.home-confort.net
they are exactly the same than chacon but cheaper (got one for 10€)
Posted: Wednesday 30 September 2015 10:16
by deennoo
Need this to !
Posted: Wednesday 30 September 2015 10:45
by sebitop
here the request in the tracker
http://www.domoticz.com/forum/tracker.php?p=2&t=615
the protocol is already available in the last RFXCOM firmware but need to be avilable on Domoticz;
Posted: Monday 19 October 2015 18:59
by slybreiz
Hello
I have several ecr-100 Module
I can not operate with a domotickz and rxfcom433E Version 248.
help thank you
Posted: Monday 19 October 2015 20:33
by b_weijenberg
Did you try with RFXmngr?
I suppose HomeConfort is not yet implemented in Domoticz, see http://www.domoticz.com/forum/tracker.php?p=2&t=615
Posted: Tuesday 20 October 2015 19:06
by slybreiz
Hello
I just tested RFXmngr.
The selection I HC tab.
and selection of telecommandeTEL-010 (the remote control supplied with the ECR-100 module is the TEL-010 model)
I try a aperage but nothing happens.
I was therefore unable to operate the ECR-module 100 ave key RFXcom433E ....
Posted: Tuesday 20 October 2015 19:29
by b_weijenberg
Use an RFXtrx433E with firmware version 248.
Connect RFXmngr and enable only the HomeConfort protocol,
Transmit a command using the TEL-010 remote.
Check the codes received and transmit a command with RFXmngr using the same codes as received from the TEL-010.
Posted: Tuesday 20 October 2015 19:34
by slybreiz
It's ok
Home Confort command
Packettype = Home Confort
subtype = TEL-010
Sequence nbr = 6
ID = 1010C decimal:65804
House Code = A
Unit Code = 1
Command = On
Signal level = 0 -120dBi
Packettype = Receiver/Transmitter Message
subtype = Transmitter Response
Sequence nbr = 6
response = ACK, data correct transmitted
subtype = TEL-010
Sequence nbr = 7
House Code = A
Unit Code = 1
Command = Off
Sequence nbr = 7
Merci Thank's :p
Posted: Wednesday 21 October 2015 10:07
by forumfab
Ok, HOME COMFORT modules are know seen under RFXmgr, but not by DOMOTICZ
Best regards
Posted: Sunday 01 November 2015 9:23
by gizmocuz
Implemented in #3524, hope it works well
Posted: Sunday 01 November 2015 11:31
by slybreiz
Nice job it's ok For me .
Posted: Sunday 01 November 2015 11:35
by gizmocuz
Great! thanks for the feedback
Posted: Monday 09 November 2015 21:57
by sebitop
bakc from business trip I will try it soon and post a feedback
thank you gizmo !!
S.
Posted: Tuesday 24 November 2015 18:10
by forumfab
gizmocuz wrote:Implemented in #3524, hope it works well
Hi gizmocuz,
Imposible to check "home confort" box in hardware set mode !
The system refuse this choice !
it's the same think with usb rfxcom 433 and usb rfxcom 433 E
Do you have an idea ?
Bests regards
