Support for rainrate?
sundberg84
Post by sundberg84 »
Error: MySensors: Unhandled sensor (sub-type=7), please report with log!
Im also trying to use v_rain but i dont know how to handle it... what should i report to domoticz?
This is from my node (rain and rainrate)
send: 6-6-0-0 s=3,c=1,t=6,pt=7,l=5,sg=0,st=ok:6.6
send: 6-6-0-0 s=3,c=1,t=7,pt=7,l=5,sg=0,st=ok:58.0
Domoticz sees it :
(MySensors Ethernet) Rain (Rain)
but if i report 6.6 its not the same number in the device.
Any clues?
Controller: Domoticz (Raspberry PI)
Gateways: MySensors (Ethernet W5100), RFLink
sundberg84
Re: Support for rainrate?
I still doesnt get the rain and how to post this to Domoticz :(
Everything i sent and recieved in domotiocz, but when i send 18.0 i get 6.5mm in the device.
Serial log from raingauge (bucket tips):
send: 6-6-0-0 s=3,c=1,t=6,pt=7,l=5,sg=0,st=ok:16.5
Rain
send: 6-6-0-0 s=3,c=1,t=6,pt=7,l=5,sg=0,st=ok:17.0
Rain
send: 6-6-0-0 s=3,c=1,t=6,pt=7,l=5,sg=0,st=ok:17.5
Rain
send: 6-6-0-0 s=3,c=1,t=6,pt=7,l=5,sg=0,st=ok:18.0
Rain
Domotiocz log:
2015-09-07 20:51:04.472 (MySensors Ethernet) Rain (Regn)
2015-09-07 20:51:05.542 (MySensors Ethernet) Rain (Regn)
2015-09-07 20:51:11.000 Hardware Monitor: Fetching data (System sensors)
2015-09-07 20:51:19.594 (MySensors Ethernet) Rain (Regn)
2015-09-07 20:51:21.645 (MySensors Ethernet) Rain (Regn)
2015-09-07 20:51:22.694 (MySensors Ethernet) Rain (Regn)
gizmocuz
Post by gizmocuz »
you need to send to domoticz the counter value, this counter need to always increase!
(you can use V_VAR1 to send/request the last counter value)
What domoticz will show, is the amount of rain received for the day
for example, the first counter value is
1.0
and the last counter value is
3.0
then there is 2.0 rain that day
please have a look at the water meter pulse example, it is the same for the rain (only a rain sensor)
sundberg84
Ok, so all you have to send is the counter value?
Not v_rain?
I uploaded the waterpulsemeter and got this:
Received last pulse count from gw:16
pulsecount:16
send: 6-6-0-0 s=1,c=1,t=24,pt=5,l=4,sg=0,st=ok:16
volume:0.016
send: 6-6-0-0 s=1,c=1,t=6,pt=7,l=5,sg=0,st=ok:0.016
Domoticz shows -0.7mm
I think i need to define how much one pulse stands for... (0.5mm in my case) but what is what in the code?
The volume sums up just as the counter...
gizmocuz
Post by gizmocuz »
You need to send the rain counter with V_RAIN
the counter is in millimeter (mm)
sundberg84
Im sorry - feel so stupid :idea:
So i request the counter with v_var1... every time the bucket tips i add another to this counter-variable and then also sends that new counter-variable with v_rain?
gizmocuz
Post by gizmocuz »
you should use/request the V_VAR1 when your node starts (powers up), so the last counter value is retrieved
dont send anything until you got this
next, when you have a pulse (bucket drop), add this value to the counter, send it with V_RAIN, and also send the counter as V_VAR1 (could also do this every minute or so)
now, this counter is in 'mm', and your system is in 0.5
so you need 2 times 0.5 to add '1' to the counter
sundberg84
Clear as water!! Thank you!! :D
One last q: Can i send 0.5 to the counter, or do the counter only have full numbers (1,2,3,4 and not 1,5 2,5...)
gizmocuz
Post by gizmocuz »
the counter is in mm, not 0.5mm, therefor you have to count internally until you have 1 mm, and then add it/send the counter
what hardware do you use that supports 0.5mm rain counter ?
sundberg84
Im trying... but no luck.
I send V_Rain every 0.5 (= 1 bucket) and counter every 1 (= 2 buckets)
So I send it like this:
V_rain 0.5
V_rain 1.0
Counter 1.0
V_Rain 1.5
V_Rain 2.0
Counter 2.0 and so on...
But in domoticz its updated with 0.6 and 0.7 mm every time i add 1 to the counter.
Its never updated when i send V_RAIN.
I want domoticz to change with 0.5mm intevalls since my bucket = 0.5mm
What am i missing??
sundberg84
Trying to understand the logic - please help!
Which one is correct?
(V_RAIN resets, but counter goes on)
Day1................Day2
V_rain 0.5 ............ V_rain 0.5
V_rain 1.0 ............ V_rain 1.0
Counter 1.0 ............ Counter 3.0
V_Rain 1.5 ............ V_Rain 1.5
V_Rain 2.0 ............ V_Rain 2.0
Counter 2.0 ............ Counter 4.0
(V_RAIN resets, counter resets)
Day1 ................ Day2
Counter 1.0 ............ Counter 1.0
Counter 2.0 ............ Counter 2.0
(V_RAIN counts on, counter counts on)
V_rain 0.5 ............ V_rain 2.5
V_rain 1.0 ............ V_rain 3.0
V_Rain 1.5 ............ V_Rain 3.5
V_Rain 2.0 ............ V_Rain 4.0
sundberg84
I figured it out - its the third example thats correct.
V_Rain and V_VAR1 (Counter) continues over time and never resets.
Example with a bucketsize of 0.5 mm:
macieiks
Post by macieiks »
Hello
Could you please share your sketch for Rain Meter ? I am thinking about building rain meter to add to my existing weather station ;). I will be using it with Ethernet Gateway.
Best regards :)
Maciek
RPI2 + RFLink + PiFace D2 + Aeon Z-Wave Gen5 + Foscams FI9821P&R2 + MySensors + UPS APC Back-UPS 950VA
RPI2 + RFXtrx433e + Foscams FI9821P + MySensors + UPS APC Back-UPS 950VA
RPIB+ + TP-Link MR3420 + Huawei E173 GarageDomoticz :)
sundberg84
Hi Maciek!
http://forum.mysensors.org/topic/1950/d ... rain-gauge
Its a normal MySensors node with a reed switch connected.
GND ---- Reed Switch ----- Pin 3
macieiks
Post by macieiks »
Thx man :D I will test it in the upcoming weekend ;)
Kajzer
Post by Kajzer »
i have another problem with my domoticz v 3.4834 on RaspberryPi. I've build weather station and last time i've installed rain gauge meter. My Domoticz use MySensors Gateway USB version 1.5.4 on Arduino. Here is the problem: Domoticz doesn't show rainrate value, still is 0. On serial monitor i see what is send to MySensors Gateway USB:
In Domoticz's log I see:
Regards.
gizmocuz
Post by gizmocuz »
I think the rain-rate should be globally implemented for all rain sensors in domoticz, not just for mysensors.
I think it is just taking the last counter value, minus the counter value from the last our, and we have a rainrate / hour correct?
Now time is my problem to implement this ;), but it cant be hard
