Page 1 of 2
Lua generic function library
Posted: Wednesday 19 August 2015 10:22
by remb0
With a friend we made some nice lua scripts.. but when you made some scripts you always need the same coding for: rounding, calculate time differences etc.
So we made the following file:
MyFunc.lua
- Spoiler: show
local My ={}
function My.GetUserVar(UserVar)
Waarde=uservariables[UserVar]
if Waarde==nil then
print(". User variable not set for : " .. UserVar)
UserVarErr=UserVarErr+1
return Waarde
function My.File_exists(file)
local f = io.open(file, "rb")
if f then f:close() end
return f ~= nil
function My.Round(num, idp)
local mult = 10^(idp or 0)
return math.floor(num * mult + 0.5) / mult
function My.GetValue(Text, GetNr)
Part=1
for match in (Text..';'):gmatch("(.-)"..';') do
if Part==GetNr then MyValue = tonumber(match) end
Part=Part+1
return MyValue
-- replace the last character
function My.EnumClear(Text)
a=string.len(Text)
b=string.sub(Text,a,a)
if b=="," or b==" " then Text=string.sub(Text,1,a-1) end
a=string.len(Text)
return Text
function My.ConvTime(TimeX)
year = string.sub(TimeX, 1, 4)
month = string.sub(TimeX, 6, 7)
day = string.sub(TimeX, 9, 10)
hour = string.sub(TimeX, 12, 13)
minutes = string.sub(TimeX, 15, 16)
seconds = string.sub(TimeX, 18, 19)
ResTime = os.time{year=year, month=month, day=day, hour=hour, min=minutes, sec=seconds}
return ResTime
function My.TimeDiff(Time1,Time2)
if string.len(Time1)>12 then Time1 = My.ConvTime(Time1) end
if string.len(Time2)>12 then Time2 = My.ConvTime(Time2) end
ResTime=os.difftime (Time1,Time2)
return ResTime
return My
You can use the functions in every lua script after you include the library with this lines:
package.path = package.path .. ';' .. '/home/pi/domoticz/scripts/lua/?.lua'
My = require('MyFunc')
Example uasage
Check if file exist.
if not My.File_exists(LogFile) then
Get UserVar and Print when missing
Get value of a user variable, but when the user variable not exist the function prints print (". User variable not set for : " .. UserVar) to the log.
When you use this function for all the variables users who copy your script gets in logging a message which variables they must make.
LogFile = My.GetUserVar("SUN_LogFile")
Get the X value of a device
5 in this example can you change in the number of the value.
my Wind meter gives: 207.00;SSW;9;18;16.4;16.4 so I need fift value for temperature
Variable = My.GetValue(otherdevices_svalues[DeviceName],5)
Round numbers.
My.Round(ValueThatNeedsToRounded,1)
TimeDifferences
The example below gave to difference between now and the time that a devices is last changed in minutes
TDiff = My.Round(My.TimeDiff(os.time(),otherdevices_lastupdate[DeviceManual])/60,0)
If you Have also some nice functions, reply with coding, explanation and example
Re: Lua generic function library
Posted: Tuesday 17 May 2016 19:15
by Yann
Worked great before but now, with the new Domoticz versions, Lua scripts are stored in the Domoticz database .... what is the package path now ?
Posted: Tuesday 17 May 2016 20:59
by SweetPants
Yann wrote:Lua scripts are stored in the Domoticz database
Only if you use the build in editor. You can still use the 'old' way for LUA scripts
Posted: Thursday 19 May 2016 15:27
by Yann
Yes, you are right, will try this. Thanks !
Posted: Saturday 28 May 2016 14:22
by Yann
Worked perfectly, thank you again !
Posted: Saturday 28 May 2016 19:42
by remb0
Yann wrote:Worked perfectly, thank you again !
thanks! feel free to post your creations to help other people.
Posted: Wednesday 01 June 2016 12:31
by Yann
Good point ! Let's do it
I wanted to create a library to send pushbullet messages to specific users. In Domoticz, the notifications settings allow only 1 pushbullet user, but I wanted to send messages either to my wife or myself. In other cases, I wanted to send a message only on Pushbullet (vs all notifications SMS/Email ...).
Hence this function
First you need to install curl in C:\programs\Curl (or other directory but then you have to change the command line bellow)
SEND MESSAGE TO PUSHBULLET
Message should be in this format 'title;message' ... so avoid ';' in your title
If you need to insert space in the text, use %20 instead otherwise the command line won't work
local Lib={};
function Lib.Pushbullet(Message)
local pb_token = 'yourpushbullettoken'
local pb_total = Message
local val=string.find(pb_total,";")
local pb_title = string.sub(pb_total,1,val-1)
local pb_body = string.sub(pb_total,val+1)
local pb_command = 'c:\\Programs\\Curl\\curl -u ' .. pb_token .. ': "https://api.pushbullet.com/v2/pushes" -d type=note -d title="' .. pb_title .. '" -d body="' .. pb_body ..'"'
-- Run curl command
exec_success = os.execute(pb_command)
return Lib
Then you can use it anywhere like this
Hope it will help someone !
Posted: Tuesday 07 March 2017 13:23
by supermat
Hi, it is not my creation, but I use it so much. I prefer use an idx rather than a name of a sensor. So I can rename the sensor an the script continues to work.
So I need to convert an idx to a name with this fonction
The code is from here :
https://www.domoticz.com/forum/viewtopic.php?t=11330
function getdevname4idx(deviceIDX)
for i, v in pairs(otherdevices_idx) do
if v == deviceIDX then
return i
return 0
Posted: Tuesday 07 March 2017 16:12
by jvdz
Thought that code looked familiar
Jos
Posted: Friday 31 March 2017 19:12
by gerard76
return ResTime
Could be written as:
function My.ConvTime(timestamp)
y, m, d, H, M, S = timestamp:match("(%d+)-(%d+)-(%d+) (%d+):(%d+):(%d+)")
return os.time{year=y, month=m, day=d, hour=H, min=M, sec=S}
Posted: Monday 03 April 2017 9:40
by emme
my most used functions:
Changed TimeDiff to get deice and variable time using one procedure
-- ++ TIME DIFFERENCE ++
-- Return seconds of last update date for a Variable or a Device
function Utils.timeDiff(dName,dType)
if dType == 'v' then
updTime = uservariables_lastupdate[dName]
elseif dType == 'd' then
updTime = otherdevices_lastupdate[dName]
t1 = os.time()
year = string.sub(updTime, 1, 4)
month = string.sub(updTime, 6, 7)
day = string.sub(updTime, 9, 10)
hour = string.sub(updTime, 12, 13)
minutes = string.sub(updTime, 15, 16)
seconds = string.sub(updTime, 18, 19)
tDiff = os.difftime(t1,t2)
return tDiff
usage: timeDiff(name,'v|d')
Convert a character separated fixed prefix string into a table
-- ++ string2table ++
-- Return a table from a char separated string for a prefixed pattern
function Utils.str2tab(Text, sepVal, prfVal)
tblVals = {}
for varName, varVal in pairs(uservariables) do
if (string.sub(varName,1,string.len(prfVal)) == prfVal) then
for tmpVal in (varName..sepVal):gmatch('([^'..sepVal..']*)'..sepVal) do table.insert(tblVals, tmpVal) end
return tblVals
usage
myTbl = {}
myTbl = Utils.str2tab(myString, ';','Light')
Posted: Wednesday 05 April 2017 23:42
by lvsigo
No need to add new package.path
Juste use dofile()
found this on french forum
https://github.com/vil1driver/lua/blob/ ... odules.lua
Posted: Friday 07 April 2017 13:32
by gerard76
using require() has benefits over dofile(). Require checks if a file is already included and does not include it again.
The standard package.path in domoticz contains the working dir. For me this is /home/pi/domoticz so I can use require('scripts/lua/group') to include my group library for example. No need to fiddle with the package path.
Posted: Friday 07 April 2017 22:49
by lvsigo
nice to know, but sorry it doesn't work (v3.7149)
print(package.path)
/usr/local/share/lua/5.2/?.lua;
/usr/local/share/lua/5.2/?/init.lua;
/usr/local/lib/lua/5.2/?.lua;
/usr/local/lib/lua/5.2/?/init.lua;
./?.lua
then only use require() result as an error
and how the file could be already included ?
I need to include it in all scripts..
dofile() do the job
Posted: Saturday 08 April 2017 6:42
by gerard76
It works, you just have to use it correctly
I do not know what your working directory is. You can find out with
then require() will work fine if you specify the correct path.
Files can be double included if any of the files you include also include other files. Any of my libraries that need to talk to the Domoticz API will include the JSON lib for example. Using require() prevents it from being included multiple times.
dofile() also works, just as (loadfile "<file path>")() the "preferred" way would be require() though.
Posted: Saturday 08 April 2017 8:56
by lvsigo
return
if I try to include modules.lua like this
require('home/lvsigo/domoticz/scripts/lua/modules')
it works
thanks
Posted: Saturday 08 April 2017 11:44
by lvsigo
Can domoticz pass to lua scripts, the lua path ?
for replacing this ?
luaDir = '/home/username/domoticz/scripts/lua/' -- linux
--luaDir = 'C:\\Program Files (x86)\\Domoticz\\scripts\\lua\\' -- windows
--luaDir = '/volume1/@appstore/domoticz/var/scripts/lua/' -- synology
Posted: Saturday 08 April 2017 13:06
by gerard76
Normally you can determine this from the script with debug.getinfo(1).source, but because the scripts are stored in the database this is not possible. At least, not to my knowledge.
Posted: Saturday 08 April 2017 17:40
by lvsigo
thanks,
this seems to works for linux or windows system
if package.config:sub(1,1) == '/' then
luaDir = debug.getinfo(1).source:match("@?(.*/)")
luaDir = string.gsub(debug.getinfo(1).source:match("@?(.*\\)"),'\\','\\\\')
print(luaDir)
maybe not optimal
Posted: Saturday 08 April 2017 23:09
by gerard76
At least its automatic. But it only works from within a file I presume? Not the lua interface in Domoticz.
