Lua generic function library
remb0
Post by remb0 »
With a friend we made some nice lua scripts.. but when you made some scripts you always need the same coding for: rounding, calculate time differences etc.
So we made the following file: MyFunc.lua
local My ={}
	function My.GetUserVar(UserVar)
		Waarde=uservariables[UserVar]
		if Waarde==nil then
			print(".  User variable not set for : " .. UserVar)
			UserVarErr=UserVarErr+1
		return Waarde
	function My.File_exists(file)
	  local f = io.open(file, "rb")
	  if f then f:close() end
	  return f ~= nil
	function My.Round(num, idp)
	   local mult = 10^(idp or 0)
	   return math.floor(num * mult + 0.5) / mult
	function My.GetValue(Text, GetNr)
		Part=1
		for match in (Text..';'):gmatch("(.-)"..';') do
		   if Part==GetNr then MyValue = tonumber(match) end
		   Part=Part+1
		return MyValue
	-- replace the last character
	function My.EnumClear(Text)
		a=string.len(Text)
		b=string.sub(Text,a,a)
		if b=="," or b==" " then Text=string.sub(Text,1,a-1) end
		a=string.len(Text)
		return Text
	function My.ConvTime(TimeX)
		year = string.sub(TimeX, 1, 4)
		month = string.sub(TimeX, 6, 7)
		day = string.sub(TimeX, 9, 10)
		hour = string.sub(TimeX, 12, 13)
		minutes = string.sub(TimeX, 15, 16)
		seconds = string.sub(TimeX, 18, 19)
		ResTime = os.time{year=year, month=month, day=day, hour=hour, min=minutes, sec=seconds}
		return ResTime
	function My.TimeDiff(Time1,Time2)
		if string.len(Time1)>12 then Time1 = My.ConvTime(Time1) end
		if string.len(Time2)>12 then Time2 = My.ConvTime(Time2) end
		ResTime=os.difftime (Time1,Time2)
		return ResTime
return My
You can use the functions in every lua script after you include the library with this lines:
package.path = package.path .. ';' .. '/home/pi/domoticz/scripts/lua/?.lua'
My = require('MyFunc')
Example uasage
Check if file exist.
	if not My.File_exists(LogFile) then
Get UserVar and Print when missing
Get value of a user variable, but when the user variable not exist the function prints print (". User variable not set for : " .. UserVar) to the log.
When you use this function for all the variables users who copy your script gets in logging a message which variables they must make.
LogFile        = My.GetUserVar("SUN_LogFile")
Get the X value of a device
5 in this example can you change in the number of the value.
my Wind meter gives: 207.00;SSW;9;18;16.4;16.4 so I need fift value for temperature
Variable      = My.GetValue(otherdevices_svalues[DeviceName],5)
Round numbers.
My.Round(ValueThatNeedsToRounded,1)
TimeDifferences
The example below gave to difference between now and the time that a devices is last changed in minutes
TDiff = My.Round(My.TimeDiff(os.time(),otherdevices_lastupdate[DeviceManual])/60,0)
If you Have also some nice functions, reply with coding, explanation and example
Yann
Re: Lua generic function library
Post by Yann »
Worked great before but now, with the new Domoticz versions, Lua scripts are stored in the Domoticz database .... what is the package path now ?
HP Microserver + Domoticz + Aeon Labs Z-Wave USB +RFX433
SweetPants
Post by SweetPants »
Yann wrote:Lua scripts are stored in the Domoticz database
Only if you use the build in editor. You can still use the 'old' way for LUA scripts
Yann
Post by Yann »
Yes, you are right, will try this. Thanks !
Yann
Post by Yann »
Worked perfectly, thank you again !
remb0
Post by remb0 »
Yann wrote:Worked perfectly, thank you again !
thanks! feel free to post your creations to help other people.
Yann
Post by Yann »
Good point ! Let's do it
I wanted to create a library to send pushbullet messages to specific users. In Domoticz, the notifications settings allow only 1 pushbullet user, but I wanted to send messages either to my wife or myself. In other cases, I wanted to send a message only on Pushbullet (vs all notifications SMS/Email ...).
Hence this function
First you need to install curl in C:\programs\Curl (or other directory but then you have to change the command line bellow)
SEND MESSAGE TO PUSHBULLET
Message should be in this format 'title;message' ... so avoid ';' in your title :D
If you need to insert space in the text, use %20 instead otherwise the command line won't work
local Lib={};
  function Lib.Pushbullet(Message)
    local pb_token = 'yourpushbullettoken'
    local pb_total = Message
    local val=string.find(pb_total,";")
    local pb_title = string.sub(pb_total,1,val-1)
    local pb_body = string.sub(pb_total,val+1)
    local pb_command = 'c:\\Programs\\Curl\\curl -u ' .. pb_token .. ': "https://api.pushbullet.com/v2/pushes" -d type=note -d title="' .. pb_title .. '" -d body="' .. pb_body ..'"'
    -- Run curl command
    exec_success = os.execute(pb_command)
return Lib
Then you can use it anywhere like this
Lib.Pushbullet('essai;text')
Hope it will help someone !
supermat
Post by supermat »
Hi, it is not my creation, but I use it so much. I prefer use an idx rather than a name of a sensor. So I can rename the sensor an the script continues to work.
So I need to convert an idx to a name with this fonction
The code is from here : https://www.domoticz.com/forum/viewtopic.php?t=11330
function getdevname4idx(deviceIDX)
 for i, v in pairs(otherdevices_idx) do
   if v == deviceIDX then
     return i
 return 0
jvdz
Domoticz version: 4.107
Post by jvdz »
Thought that code looked familiar :-)
Jos
gerard76
Domoticz version: 3.8153
Post by gerard76 »
  return ResTime
Could be written as:
function My.ConvTime(timestamp)
   y, m, d, H, M, S = timestamp:match("(%d+)-(%d+)-(%d+) (%d+):(%d+):(%d+)")
   return os.time{year=y, month=m, day=d, hour=H, min=M, sec=S}
emme
Domoticz version: latest
Post by emme »
my most used functions:
Changed TimeDiff to get deice and variable time using one procedure
-- ++      TIME DIFFERENCE        ++
-- Return seconds of last update date for a Variable or a Device
    function Utils.timeDiff(dName,dType)
        if dType == 'v' then
            updTime = uservariables_lastupdate[dName]
        elseif dType == 'd' then
            updTime = otherdevices_lastupdate[dName]
        t1 = os.time()
        year = string.sub(updTime, 1, 4)
        month = string.sub(updTime, 6, 7)
        day = string.sub(updTime, 9, 10)
        hour = string.sub(updTime, 12, 13)
        minutes = string.sub(updTime, 15, 16)
        seconds = string.sub(updTime, 18, 19)
        tDiff = os.difftime(t1,t2)
        return tDiff
usage: timeDiff(name,'v|d')
Convert a character separated fixed prefix string into a table
-- ++         string2table        ++
-- Return a table from a char separated string for a prefixed pattern
    function Utils.str2tab(Text, sepVal, prfVal)
        tblVals = {}
        for varName, varVal in pairs(uservariables) do
            if (string.sub(varName,1,string.len(prfVal)) == prfVal) then
                for tmpVal in (varName..sepVal):gmatch('([^'..sepVal..']*)'..sepVal) do table.insert(tblVals, tmpVal) end
        return tblVals
usage
myTbl = {}
myTbl = Utils.str2tab(myString, ';','Light')
"We always done this way"
lvsigo
Post by lvsigo »
No need to add new package.path
Juste use dofile()
found this on french forum
https://github.com/vil1driver/lua/blob/ ... odules.lua
gerard76
Post by gerard76 »
using require() has benefits over dofile(). Require checks if a file is already included and does not include it again.
The standard package.path in domoticz contains the working dir. For me this is /home/pi/domoticz so I can use require('scripts/lua/group') to include my group library for example. No need to fiddle with the package path.
lvsigo
Post by lvsigo »
nice to know, but sorry it doesn't work (v3.7149)
print(package.path)
/usr/local/share/lua/5.2/?.lua;
/usr/local/share/lua/5.2/?/init.lua;
/usr/local/lib/lua/5.2/?.lua;
/usr/local/lib/lua/5.2/?/init.lua;
./?.lua
then only use require() result as an error
and how the file could be already included ?
I need to include it in all scripts..
dofile() do the job ;)
gerard76
Post by gerard76 »
It works, you just have to use it correctly ;)
I do not know what your working directory is. You can find out with
print(io.popen("pwd"):read'*l')
then require() will work fine if you specify the correct path.
Files can be double included if any of the files you include also include other files. Any of my libraries that need to talk to the Domoticz API will include the JSON lib for example. Using require() prevents it from being included multiple times.
dofile() also works, just as (loadfile "<file path>")() the "preferred" way would be require() though.
lvsigo
Post by lvsigo »
return
if I try to include modules.lua like this
require('home/lvsigo/domoticz/scripts/lua/modules')
it works
thanks ;)
lvsigo
Post by lvsigo »
Can domoticz pass to lua scripts, the lua path ?
for replacing this ?
luaDir = '/home/username/domoticz/scripts/lua/'					-- linux
--luaDir = 'C:\\Program Files (x86)\\Domoticz\\scripts\\lua\\'			-- windows
--luaDir = '/volume1/@appstore/domoticz/var/scripts/lua/'			-- synology
gerard76
Post by gerard76 »
Normally you can determine this from the script with debug.getinfo(1).source, but because the scripts are stored in the database this is not possible. At least, not to my knowledge.
lvsigo
Post by lvsigo »
thanks,
this seems to works for linux or windows system
if package.config:sub(1,1) == '/' then
	luaDir = debug.getinfo(1).source:match("@?(.*/)")
	luaDir = string.gsub(debug.getinfo(1).source:match("@?(.*\\)"),'\\','\\\\')
print(luaDir)
maybe not optimal ;)
gerard76
Post by gerard76 »
At least its automatic. But it only works from within a file I presume? Not the lua interface in Domoticz.
