RFLink: List of supported devices
- Domoticz version: current
Re: RFLink: List of supported devices
This list is really useful for checking if a device that you have found online is compatible with RFLink.
But it would be useful if it would also work the other way around: that once I have chosen to go with RFLink, I can use this list as a startingpoint to find compatible devices for my needs. For example: I would like to know which temperature sensors I can buy that are compatible with RFLink. The current list doesn't help me with this task.
A quick way of fixing this would be to turn the list into a table, and add data about the devices: what they do (tags?), what they cost, and links to buy these maybe (which may be a source of income for this project?).
Home Assistant does this the best probably: https://home-assistant.io/components
- Domoticz version: Beta Ch
Prologue 36-4744 (Clas Ohlsson) works out of the box.
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
- Stuntteam
Thanks for reporting..
I am planning to buy an RF link, and attach it to my Udoo Quad, with domoticz already installed.
Is this possible?
Is this possible?
- Stuntteam
Sure..
tontze wrote:Prologue 36-4744 (Clas Ohlsson) works out of the box.
Except now im seeing that it allways reports battery low, even tho there is new batteries. Dont know if this false report from module itself, how can i test it ? Got 3 of these, and all says low battery ...Stuntteam wrote:Thanks for reporting..
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
- Stuntteam
Make a short debug log (look here: http://www.nemcon.nl/blog2/development)
and mail me that ([email protected])
Then I will take a look and correct it if needed.
Email sentStuntteam wrote:Make a short debug log (look here: http://www.nemcon.nl/blog2/development)
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
I'm looking to buy some cheap RF switches that you plug into a wall socket.
These "FW1S" are the cheapest I could find on AliExpress:
https://www.aliexpress.com/item/FW1S-EU ... 52503.html
- Are they supported? I'm guessing not.
- It would be so cool if RFLink could record and re-broadcast any arbitrary RF signal. Then I wouldn't have to ask, then Domoticz could just copy the remote's codes.
- Domoticz version: 4.11333
I have them. They are not working with RFlink. I've send RFlink and RM broadlink (they are working with RM) codes to Frank Zirrone 16.02.2017, but no reply.
____
may
____
may
_______________
- Dell FX-160 / Ubuntu 16.04
- RFLink 433Mhz / NRF 2.4GHz
- 2x Xiaomi Gateway
- different species of ESP8266
- 2x Xiaomi Gateway
- Stuntteam
For 17 euros the set is a piece of junk.. Go to the Action store and get a set for 10 euros.
Anyway, the FW1S set will probably supported by R46 (available soon)
Working OutOfBox Firmware R46 - BAHUON BHC9938F-X (set of 3 433Mhz 230VAC Socket plugs with Remote identified by remote number - 1415 for example - and 1/2/3 plug number)
Not working - firmware R46 - 230VAC socket "RisingSun (Conrad) RSL3660-F Rx" 230V-16A 3500W.
Identified by HouseCode (I-II-III-IV)/UnitCode (1-2-3-4)
The ON command send through Domoticz does nothing (using ARC / COCO GDR2 / RisingSun).
I have only sockets (no remote to learn code)
- Stuntteam
Use RFlink loader, make a serial connection
Put the socket in learning mode and enter the following command to pair it:
10;CONRAD;960500;5;PAIR;
In Domoticz, got to [settings,hardware] use the [create rflink device] button and enter the following in the popup:
20;0E;Conrad;ID=960500;SWITCH=05;CMD=ON;
- Westcott
Hi Stuntteam,
I've captured this from a working Solla remote, and created a device, but it doesn't work, although it transmits correctly.
20;66;TriState;ID=099590;SWITCH=1;CMD=ON;
- Stuntteam
Try the rffind option.. or send a debug log to [email protected]
- Westcott
RFfind?
- Stuntteam
I have one of those but it does not work so well for me. I have home assistant on my RPi2 with a tellstick duo.tontze wrote:Prologue 36-4744 (Clas Ohlsson) works out of the box.
Is there any connection procedure I'm supposed to do?
Im using rflink, dont know anything about tellstickHeldestad wrote:I have one of those but it does not work so well for me. I have home assistant on my RPi2 with a tellstick duo.tontze wrote:Prologue 36-4744 (Clas Ohlsson) works out of the box.
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
