RFLink: List of supported devices
433Mhz opensource Receiver & Transmitter.
blauwebuis
Domoticz version: current
Re: RFLink: List of supported devices
Post by blauwebuis »
This list is really useful for checking if a device that you have found online is compatible with RFLink.
But it would be useful if it would also work the other way around: that once I have chosen to go with RFLink, I can use this list as a startingpoint to find compatible devices for my needs. For example: I would like to know which temperature sensors I can buy that are compatible with RFLink. The current list doesn't help me with this task.
A quick way of fixing this would be to turn the list into a table, and add data about the devices: what they do (tags?), what they cost, and links to buy these maybe (which may be a source of income for this project?).
Home Assistant does this the best probably: https://home-assistant.io/components
tontze
Domoticz version: Beta Ch
Post by tontze »
Prologue 36-4744 (Clas Ohlsson) works out of the box.
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
Stuntteam
Post by Stuntteam »
Thanks for reporting..
Ewaldharmsen
Post by Ewaldharmsen »
I am planning to buy an RF link, and attach it to my Udoo Quad, with domoticz already installed.
Is this possible?
Stuntteam
Post by Stuntteam »
Sure..
tontze
Post by tontze »
tontze wrote:Prologue 36-4744 (Clas Ohlsson) works out of the box.
Stuntteam wrote:Thanks for reporting..
Except now im seeing that it allways reports battery low, even tho there is new batteries. Dont know if this false report from module itself, how can i test it ? Got 3 of these, and all says low battery ...
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Stuntteam
Post by Stuntteam »
Make a short debug log (look here: http://www.nemcon.nl/blog2/development)
and mail me that ([email protected])
Then I will take a look and correct it if needed.
tontze
Post by tontze »
Stuntteam wrote:Make a short debug log (look here: http://www.nemcon.nl/blog2/development)
Email sent :)
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
blauwebuis
I'm looking to buy some cheap RF switches that you plug into a wall socket.
These "FW1S" are the cheapest I could find on AliExpress:
https://www.aliexpress.com/item/FW1S-EU ... 52503.html
- Are they supported? I'm guessing not.
- It would be so cool if RFLink could record and re-broadcast any arbitrary RF signal. Then I wouldn't have to ask, then Domoticz could just copy the remote's codes.
mayyam
Domoticz version: 4.11333
Post by mayyam »
I have them. They are not working with RFlink. I've send RFlink and RM broadlink (they are working with RM) codes to Frank Zirrone 16.02.2017, but no reply.
____
may
_______________
- Dell FX-160 / Ubuntu 16.04
- RFLink 433Mhz / NRF 2.4GHz
- 2x Xiaomi Gateway
- different species of ESP8266
Stuntteam
Post by Stuntteam »
For 17 euros the set is a piece of junk.. Go to the Action store and get a set for 10 euros.
Anyway, the FW1S set will probably supported by R46 (available soon)
lipon67
Post by lipon67 »
Working OutOfBox Firmware R46 - BAHUON BHC9938F-X (set of 3 433Mhz 230VAC Socket plugs with Remote identified by remote number - 1415 for example - and 1/2/3 plug number)
lipon67
Post by lipon67 »
Not working - firmware R46 - 230VAC socket "RisingSun (Conrad) RSL3660-F Rx" 230V-16A 3500W.
Identified by HouseCode (I-II-III-IV)/UnitCode (1-2-3-4)
The ON command send through Domoticz does nothing (using ARC / COCO GDR2 / RisingSun).
I have only sockets (no remote to learn code)
Stuntteam
Post by Stuntteam »
Use RFlink loader, make a serial connection
Put the socket in learning mode and enter the following command to pair it:
10;CONRAD;960500;5;PAIR;
In Domoticz, got to [settings,hardware] use the [create rflink device] button and enter the following in the popup:
20;0E;Conrad;ID=960500;SWITCH=05;CMD=ON;
Westcott
Post by Westcott »
Hi Stuntteam,
I've captured this from a working Solla remote, and created a device, but it doesn't work, although it transmits correctly.
20;66;TriState;ID=099590;SWITCH=1;CMD=ON;
Stuntteam
Post by Stuntteam »
Try the rffind option.. or send a debug log to [email protected]
Westcott
Post by Westcott »
RFfind?
Stuntteam
Post by Stuntteam »
Heldestad
Post by Heldestad »
I have one of those but it does not work so well for me. I have home assistant on my RPi2 with a tellstick duo.
Is there any connection procedure I'm supposed to do?
tontze
Post by tontze »
Im using rflink, dont know anything about tellstick :)
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
