Page 1 of 2
Mysensors - Domoticz windows - cant get connection
Posted: Thursday 13 August 2015 4:51
by punter9
Looking for a helping hand. I have the following (I am only about 3 hours into this so please be basic);
- Windows 10 PC with Domoticz latest release going
serial gateway
- Arduino Uno (real) with NRF24L01+ done just as shown on this website
http://www.mysensors.org/build/serial_gateway
First Sensor
-Arduino Uno (real) with NRF24L01+ done just as shown on this website (have a 135 instead of a MQ2 hooked up)
http://www.mysensors.org/build/gas
I hook up the gateway and set up hardware. I go to COM7 (where the gateway is) name it and add it. I see nothing confirming it is working. Thoughts?
I have the gas sensor across the room plugged in, nothing shows up in devices.
Am I missing a critical step here?
here is an image
https://www.amazon.com/clouddrive/share ... _link_copy
Re: Mysensors - Domoticz windows - cant get connection
Posted: Thursday 13 August 2015 8:06
by Justintime
Have you checked in the arduino serial window if everything is OK?
On both mysensors devices.
So no fail messages?
Be sure to set in the Domoticz settings window "allow new hardware devices" and then add the new hardware.
If you added the serial gateway. Do it again for the Node. You should see in the log that the node is accepted.
Posted: Thursday 13 August 2015 12:27
by gizmocuz
This sensor type is not (yet) supported, i have a patch, but i would like to double check everything before i commit it
But for now, please check with this application if all is correctly connected/received:
http://www.mysensors.org/controller/myscontroller
Posted: Thursday 13 August 2015 19:12
by punter9
well that tells you how green I am with this deal. I didn't think to check serial monitor outputs on the gateway. Turns out all I am getting is some weird characters, nothing intelligible. I am sure this is an issue. I am going to uninstall all my arduino related files and reinstall it with only the mysensors examples in it.
Thanks for the responses, and being polite to this noob.
Posted: Thursday 13 August 2015 22:38
by Justintime
punter9 wrote:well that tells you how green I am with this deal. I didn't think to check serial monitor outputs on the gateway. Turns out all I am getting is some weird characters, nothing intelligible. I am sure this is an issue. I am going to uninstall all my arduino related files and reinstall it with only the mysensors examples in it.
If you get weird charactars.... be sure to set the baud rate at 115200.
Posted: Thursday 13 August 2015 23:01
by gizmocuz
Back on the OP topic, could you try version #2725 to see if the air quality sensor is working?
(almost complete rebuild of the mysensors support)
I also recommend (but you can do this later) to restart all nodes, as we now store the presentation types
later, i want to make a complete manager for the gui, or at least a good visible representation of the current nodes and child types
best to test first with the above application to do a second verification if all is working well,
what also works is to open the serial console in the arduino ide for logging
Posted: Friday 14 August 2015 1:33
by punter9
Ok. Getting closer!
Baud rate was key. I have always used 9k baud for my home projects so I didn't think of that at all. Thank you!
I am getting this from the serial gateway.
0;0;3;0;9;gateway started, id=0, parent=0, distance=0
0;0;3;0;14;Gateway startup complete.
I am getting this from the sensor.
find parent
send: 105-105-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
find parent
nobody is finding anybody! Tips?
Also I erased my serial gateway and went to add it but it now no longer shows com port 7 (even though arduino IDE shows it on port 7 and uploads to it....) any suggestions here?
Posted: Friday 14 August 2015 2:42
by punter9
okay I went into device manager and changed the com port from 7 to 2. Now Domoticz shows COM 2 but I am getting no indication it is actually obtaining any information from it. Image looks just like the one posted above except with com2 active. This is really weird.
Posted: Friday 14 August 2015 3:04
by punter9
this seems very important from the domoticz log - note I switched from com 2 to com 7 again
2015-08-13 19:53:26.024 Error: MySensors: Error opening serial port!
2015-08-13 19:53:27.026 MySensors: retrying in 30 seconds...
2015-08-13 19:53:56.069 MySensors: Using serial port: COM2
2015-08-13 19:53:56.069 Error: MySensors: Error opening serial port!
2015-08-13 19:53:57.084 MySensors: retrying in 30 seconds...
2015-08-13 19:54:26.121 MySensors: Using serial port: COM2
2015-08-13 19:54:26.693 MySensors: Gateway Ready...
2015-08-13 19:56:04.585 Error: Serial Port closed!... Error: The I/O operation has been aborted because of either a thread exit or an application request
2015-08-13 19:56:05.297 MySensors: retrying in 30 seconds...
2015-08-13 19:56:34.749 MySensors: Using serial port: COM2
2015-08-13 19:56:35.623 MySensors: Gateway Ready...
2015-08-13 20:01:26.940 MySensors: Using serial port: COM7
2015-08-13 20:01:26.940 Error: MySensors: Error opening serial port!
2015-08-13 20:01:27.941 MySensors: retrying in 30 seconds...
2015-08-13 20:01:31.955 MySensors: Serial Worker stopped...
Posted: Friday 14 August 2015 12:23
by gizmocuz
First try to get it working with the application from the third post
Posted: Friday 14 August 2015 16:54
by punter9
I am working on it, not exactly sure how to use the program yet, but hey that is part of the fun! My knowledge before is writing code for stand alone plant watering, temp, etc. This whole inter arduino communication is all new to me!
Posted: Saturday 15 August 2015 6:07
by punter9
success! All is working and my first sensor shows up in domoticz. Thanks for the help! Time to build out this dumbhouse!
Posted: Saturday 05 December 2015 0:29
by Lyubomyr
How did You succeed?? I'm having troubles with MQ-2. It works fine with Arduino sketch that I've found in the reference link on Mysensors.org. It outputs data in Serial Monitor when I use sketch for domoticz, but Domotics doesn't see it. I mean that in LOG of Domoticz there is mentioned that Air quality sketch/module is present, but I don't see such sensor in the device list.
Please, help me.
Posted: Saturday 05 December 2015 8:48
by gizmocuz
did you enable 'accept new hardware sensors' in the settings page ?
Posted: Saturday 05 December 2015 8:53
by Lyubomyr
Yes!
I suppose this is why I see Air Control in the Log.
Posted: Saturday 05 December 2015 8:56
by gizmocuz
Is it the sketch from the following link:
Posted: Saturday 05 December 2015 9:12
by Lyubomyr
Yes, it is.
But I connected only three wires
Vcc ->5V
GND-> Ground
A0 -> A0
I left D0 pin of the sensor unconnected, since it works in the Arduino UDE.
Posted: Saturday 05 December 2015 10:34
by gizmocuz
Made a test sketch, and its working fine, make sure you are on one of the latest versions
// Enable debug prints to serial monitor
#define MY_DEBUG
// Enable and select radio type attached
#define MY_RADIO_NRF24
//#define MY_RADIO_RFM69
#define MY_NODE_ID 253
#include <SPI.h>
#include <MySensor.h>
#define CHILD_ID_GAS 0
unsigned long SLEEP_TIME = 30*1000; // Sleep time between reads (in milliseconds)
MyMessage msg(CHILD_ID_GAS, V_LEVEL);
void setup()
void presentation() {
  // Send the sketch version information to the gateway and Controller
  sendSketchInfo("Test Gas Sensor", "1.0");
  present(CHILD_ID_GAS, S_AIR_QUALITY);
void loop() {
  int gasvalue=123;
  Serial.println(gasvalue);
  send(msg.set((long)ceil(gasvalue)));
  // Power down the radio.  Note that the radio will get powered back up
  // on the next write() call.
  sleep(SLEEP_TIME); //sleep for: sleepTime
Posted: Saturday 05 December 2015 10:52
by Lyubomyr
Thank You.
The test sketch works perfectly!
Posted: Saturday 05 December 2015 10:54
by gizmocuz
Great, now hack your MQ-2 reading in it ;)
