Google voice in Wiki
oopee
Domoticz version: 3.x
Post by oopee »
Google translate https://www.domoticz.com/wiki/Google_voice has changed resulting error 503 when using script from Wiki. Browser shows a captcha dialogue now.
To get it working again, a string "&ie=UTF-8&total=1&idx=0&client=t" must be added to the script.
My current script for speaking Domoticz is now:
#!/bin/bash
say() { local IFS=+;/usr/bin/mplayer -ao alsa -really-quiet -noconsolecontrols "http://translate.google.com/translate_tts?tl=fi&q=$*&ie=UTF-8&total=1&idx=0&client=t"; }
say $*
There may be other (better?) ways to fix this issue but this was the first I found.
pvm
Domoticz version: 4.10538
Re: Google voice in Wiki
Post by pvm »
Thnx! Was looking for this for my Bluetooth speaker
ThinkPad
Post by ThinkPad »
Feel free to change the wiki, login credentials are the same as for this forum :)
Thanks for reporting.
pvm
Post by pvm »
pvm wrote:Thnx! Was looking for this for my Bluetooth speaker
Too bad...it does not work for me:
pi@raspberrypi ~/btaudio $ wget "http://translate.google.com/translate_tts?tl=nl&q=test&ie=UTF-8&total=1&idx=0&client=t"
--2015-08-11 11:19:46--  http://translate.google.com/translate_tts?tl=nl&q=test&ie=UTF-8&total=1&idx=0&client=t
Resolving translate.google.com (translate.google.com)... 173.194.65.113, 173.194.65.100, 173.194.65.101, ...
Connecting to translate.google.com (translate.google.com)|173.194.65.113|:80... connected.
HTTP request sent, awaiting response... 403 Forbidden
2015-08-11 11:19:46 ERROR 403: Forbidden.
oopee
Post by oopee »
If you try your string (from same network as your Domoticz) http://translate.google.com/translate_t ... 0&client=t in browser, do you get it spoken and without captcha?
My error was 503, not 403. Without the added part, do you get 503?
pvm
Post by pvm »
Yes I do, I seem to have another issue. I am able to download files from the internet on my Pi. Internet access seems ok
oopee
Post by oopee »
It might be that with WGET you need to fake some HTTP headers if possible. See: http://stackoverflow.com/questions/9893 ... speech-api.
pvm
Post by pvm »
oopee wrote:It might be that with WGET you need to fake some HTTP headers if possible. See: http://stackoverflow.com/questions/9893 ... speech-api.
Thnx, the following produces a valid mp3 file
curl 'http://translate.google.com/translate_tts?ie=UTF-8&q=Hello&tl=en&client=t' -H 'Referer: http://translate.google.com/' -H 'User-Agent: stagefright/1.2 (Linux;Android 5.0)' > google_tts.mp3
pvm
Post by pvm »
I added this information to the google_voice wiki page
uNGam3R
Post by uNGam3R »
Thanks, your solution works great :)
Want more about Domoticz scripts and DiY devices?
Go to ---------- http://mydomotic.blogspot.com
BobbyNL
Post by BobbyNL »
is there someone who can create a working google_voice.sh file and a sample script_device_switch.lua?
i have sound working on my rpi (can play a mp3 file with mplayer) but google.translate produces no sound even when the script is triggered.
So i think my google_voice.sh and script_device_switch isnt correct.
Rpi-Domoticz +RFXtrx433E | Rpi-Openelec | Rpi-Runeaudio | unRaid 6 server | Intel NUC-Linux Tvheadend + Oscam
BobbyNL
Post by BobbyNL »
Could not get it working with google text to speech because google blocks my ip after one request.
So I had to find another solution. Now it works with the voicerss api.
I created a wiki page how I did it: http://www.domoticz.com/wiki/Rss_voice
pvm
Post by pvm »
Indeed Google blocks, thats why you can use:
pvm wrote: Thnx, the following produces a valid mp3 file
pvm
Post by pvm »
Btw, Amazon its tts sounds better than googles. You need a free developers license though. I am using that one
BobbyNL
Post by BobbyNL »
And what code do you use the bash file ?
pvm
Post by pvm »
BobbyNL wrote:is there someone who can create a working google_voice.sh file and a sample script_device_switch.lua?
What happend on command line (no script) if you produce the mp3 file and step 2 play it with mplayer?
BobbyNL
Post by BobbyNL »
it works for a few requests. But after a while i get this error.
pi@raspberrypi ~/domoticz/scripts $ sudo ./google_voice.sh
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100  1771  100  1771    0     0   3495      0 --:--:-- --:--:-- --:--:--  4052
Creating config file: /root/.mplayer/config
MPlayer svn r34540 (Raspbian), built with gcc-4.6 (C) 2000-2012 MPlayer Team
mplayer: could not connect to socket
mplayer: No such file or directory
Failed to open LIRC support. You will not be able to use your remote control.
Playing google_tts.mp3.
libavformat version 53.21.1 (external)
Mismatching header version 53.19.0
libavformat file format detected.
[mp3 @ 0xb5da2850]Header missing
[mp3 @ 0xb64800e8]Could not find codec parameters (Audio: mp3, 0 channels, s16)
[mp3 @ 0xb64800e8]Estimating duration from bitrate, this may be inaccurate
LAVF_header: av_find_stream_info() failed
Exiting... (End of file)
And opening the mp3 file. Looks clear to my that the server blocks my IP even with this mp3 (solution)
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head><meta http-equiv="content-type" content="text/html; charset=utf-8"><meta name="viewport" content="initial-scale=1"><title>http://www.google.com/</title></head>
<body style="font-family: arial, sans-serif; background-color: #fff; color: #000; padding:20px; font-size:18px;" onload="e=document.getElementById('captcha');if(e){e.focus();}">
<div style="max-width:400px;">
 <hr noshade size="1" style="color:#ccc; background-color:#ccc;"><br>
  <div style="font-size:13px;">
   Our systems have detected unusual traffic from your computer network.  Please try your request again later.  <a href="#" onclick="document.getElementById('infoDiv0').style.display='block$
   <div id="infoDiv0" style="display:none; background-color:#eee; padding:10px; margin:0 0 15px 0; line-height:1.4em;">
    This page appears when Google automatically detects requests coming from your computer network which appear to be in violation of the <a href="//www.google.com/policies/terms/">Terms of$
   </div><br>
 IP address: xx.xxx.xx.xx<br>Time: 2015-11-01T16:26:59Z<br>URL: http://www.google.com/<br>
 </div>
</div>
</body>
</html>
jmleglise
Domoticz version: 2022.1
Post by jmleglise »
Google voice controls the number of call per IP. So if you have a dynamic IP, and are not lucky, you may be banned.
If so, use VoiceRSS. I have updated the wiki with a VoiceRSS howto, look here : https://www.domoticz.com/wiki/Talking_Domoticz
My script : https://github.com/jmleglise
RFXTRX433E: Blind Somfy RTS, Portal Somfy Evolvia, chacon IO, Oregon, PIR sensor PT2262
My Last project : Location de vacances a Ouistreham vue mer
KMTronic USB relay
Chinese Z-WAVE: Neo CoolCam
