Zwave not fully initialized
Posted: Saturday 25 July 2015 9:49
by piet2000
I have the message: Not all Nodes have been Queried yet, OpenZWave not fully initialized yet! and it will not disappear after a while.
Is there a way to sort out which nodes aren't queried yet?
Re: Zwave not fully initialized
Posted: Saturday 25 July 2015 10:52
by piet2000
Problem solved: after searching arround on the web.
I disabled the openzwave in the hardware tab.
I renamed the zwcfg_[contr_id].xml
I enabled the openzwave again.
This fixed the issue.
Posted: Saturday 25 July 2015 11:32
by ThinkPad
What did you change the name in to? Just some random text?
I have the same problem on my Synology NAS, maybe this will solve it.
Posted: Saturday 25 July 2015 12:00
by jvdz
I had the same issue this morning and did what was suggested in another thread and remove the noteid 0 from config file zwcfg_????????.xml.
- Stop Domoticz
- make a savecopy of /home/pi/domoticz/Config/zwcfg_????????.xml
- Edit /home/pi/domoticz/Config/zwcfg_????????.xml and removed below section
[*]Sart Domoticz
<Node id="0" name="" location="" basic="0" generic="0" specific="0" type="" listening="true" frequentListening="false" beaming="false" routing="false" max_baud_rate="0" version="0" query_stage="Probe">
<Manufacturer id="" name="">
<Product type="" id="" name="" />
</Manufacturer>
<CommandClasses />
</Node>
Jos
Posted: Sunday 26 July 2015 10:36
by piet2000
Yes, I renamed it to .old extension.
But I was to glorious in my post. I have two AEOTEC devices which stop functioning
.. still working to sort that out.
Posted: Sunday 26 July 2015 11:46
by piet2000
The AEOTEC sensors works again, resetting them to default and learned again to the z-wave network did the trick
Posted: Sunday 26 July 2015 12:06
by Domosapiens
[Edit: Just see above that you solved the problem]
1)
Last June there was a big rename from aeon to aeotec.
Take a look here:
http://sourceforge.net/p/domoticz/code/ ... ig/aeotec/
Your Domoticz version is probably from before this renaming action
2)
All devices need to have:
Search the zwcfg_?????.xml for devices that are not "Complete".
3)
Some newer devices do need a SecurityReport during the query process, while the device xml is not up-to-date (or not there at all)
See this post:
http://www.domoticz.com/forum/viewtopic ... 271#p40840
and the next one for the query process,
and how to help Z-wave trough this query step.
4)
@Piet
You don't mention the type of devices and if there is a device xml.
That limits the amount of help you can expect
Hope this helps,
Domosapiens
Posted: Monday 27 July 2015 7:26
by Egregius
I had the same notification in zwave panel.
Yesterday I removed the zwcfg_??.xml file. After a reboot still the same problem.
This morning: no more notification and all devices show query_stage="Complete", even after a reboot.
I guess that you have to be patient after removing the XML if you have devices with a very long wake up interval.
Posted: Monday 27 July 2015 16:44
by Ralph
This seem to have fixed my "Not all Nodes have been Queried yet, OpenZWave not fully initialized yet!" problem:
(Note, I'm a noob, if anyone has suggestions they are welcome to let me know..)
1. Putty into the shell
2. Get admin privileges..
3. Go to the Config dir
4. Stop your Domoticz
5. Find and edit your xml with nano
-> Find the node where the first line doesn't end in query="complete", in my case indeed Node 0)
-> Remove the lines <Node id="0"> .... </Node> (5 lines in my case) with Ctrl-K
-> Exit (Ctrl-X) and save (Y)
6. Start your Domoticz
After a minute or so the message was gone and the button turned blue.
Posted: Monday 27 July 2015 21:24
by ThinkPad
How can i fix this on my Synology? According to the Domoticz log it uses a config in '/usr/local/domoticz/Config'.
I have looked in that folder, but there is no zwave_0x????.xml file (the ?? are different for each config, i know).
Only XML-files there are the 'device_classes.xml' and 'manufacturer_specific.xml' (and all the folders per devicebrand).
The Z-wave devices are working fine in Domoticz, but the Setup button stays red, even after a few days.
I would like to edit the file like described above, but then i first shall have to find it
Edit: And when i now click on 'Setup' there are no devices shown? Not even the controller.... wtf?
Posted: Monday 27 July 2015 23:34
by Ralph
I checked just to be sure..
My razberry install doesn't have a /usr/local/domoticz/Config, it's /home/pi/domoticz/Config. I'm sure it should be the same though.. I see the files you have, plus options.xml, zwcfg_0x????????.xml and zwscene.xml. And my backup of course.. There are also .xsd files for each xml.
I'm also pretty confident that, if you remove the zwcfg, you remove the devices. Egregius wrote that after the xml file is removed it takes a while for the system to rebuild it, let us know how it works out for you..
Note: the ???????? is the Z-Wave Home ID, you can find it in the Z-Wave control panel (
http://domoticz:8080/ozwcp/cp.html)
Posted: Tuesday 28 July 2015 10:18
by ThinkPad
I know, but i run Domoticz on my NAS, so because of that the directories are different. And i saw in the Domoticz log that Openzwave used the '/usr/local/domoticz/Config' folder. But like i said, i can't find those .xml files that were mentioned there. I do have the .xsd files.
I will try a rebuild (by clicking 'Heal network' i guess?)
Posted: Tuesday 28 July 2015 12:30
by Egregius
Try this in SSH on Synology (could take some minutes):
It will search the entire volume for directories with the name Config (case sensitive!)
I just removed the entire zwcfg...xml file (after backing it up offcourse)
Posted: Tuesday 28 July 2015 18:32
by ThinkPad
Thanks. I had to change it a bit (it didn't recognize the '-d' parameter, had to change it into '-type d')
It only found this folder: /volume1/@appstore/domoticz/Config
But no .xml file there. I also can't get the Z-Wave working again. I removed the Aeon stick under Hardware and added it again, but nothing shows up under the 'Setup' button. I will also try removing, restarting Domoticz, re-adding the stick.
Or maybe i can copy the .xml file from my PC, because the devices were detected correctly there....
Posted: Tuesday 28 July 2015 22:15
by Ralph
Do you have a backup you can restore? Maybe you could try including a node (or excluding/including again) just to see if a new file is built..
edit: Hmm.. ok, yeah.. Your xml from the pc would be a proper backup as well
Posted: Wednesday 29 July 2015 7:31
by ThinkPad
I will try and let you know, don't have much time to look into this atm.
Posted: Saturday 02 January 2016 17:33
by gjnijenhuis
I have also been struggling to find this file on my Synology.
Here is where you (or at least I) can find the xml file:
/volume1/@appstore/domoticz/var
Posted: Saturday 02 January 2016 17:58
by jvdz
on the raspberry it is located in the "/home/pi/domoticz/Config" directory.
Jos
