Doorbell stays "on"
Posted: Thursday 23 July 2015 20:11
by pecora
I try to build an event with my doorbell, it needs to be "off" but it stays always "on".
Did I something wrong...
Re: Doorbell stays "on"
Posted: Thursday 23 July 2015 20:40
by LJ80
pecora wrote:I try to build an event with my doorbell, it needs to be "off" but it stays always "on".
I think you need to give more info, what event, which type of doorbell etc.
Posted: Thursday 23 July 2015 21:04
by bizziebis
You could edit your doorbell switch and add an off delay of 5 seconds or so.
Posted: Thursday 23 July 2015 22:15
by Heisenberg
without more info or screenshots it's error guessing
Posted: Wednesday 25 November 2015 19:01
by badubo
same issue, did you find any solution?
Posted: Wednesday 25 November 2015 20:29
by pj-r
If you dont have off button in your doorbell you have to edit it and set off delay manually. Or how do you think it knows to go back to off state. Same thing with PiR..
Posted: Wednesday 25 November 2015 21:10
by StanHD
I don't think you need to turn it off.
I pause my Sonos like this:-
My doorbell switch is always on but blockly waits for a "new" on before it triggers again. I just press the Sonos switch back on again to resume play.
Posted: Wednesday 25 November 2015 23:50
by G3rard
The doorbell in Domoticz does not have an off delay.
I have solved this by making a virtual switch and a LUA script that turns that switch on when the doorbell is rang. In that virtual switch I have set an off delay of 10 seconds.
If you use that switch in your commands (eg pause TV) then it will work.
LUA code
if (devicechanged['doorbell']) then
if otherdevices['virtual_doorbell_switch']=='Off' then
commandArray['virtual_doorbell_switch']='On'
Posted: Thursday 26 November 2015 15:38
by Mediacj
Nice solution but a short period before it gone off after a short time at itself. I used it to put my tv on pause and to automatically switch the light at the door
Maybe there has been changed something.
Posted: Friday 27 November 2015 10:15
by pj-r
G3rard wrote:The doorbell in Domoticz does not have an off delay.
Oh, didnt know that
You could do the same thing then with "push on" button and off delay.. or pir.. or.. of course it would lead to wrong icon.
Posted: Wednesday 06 January 2016 15:51
by smokinjoev
Here is my setup for a driveway buried magnetic sensor that alerts me with a tone when someone drives up my driveway....
- event1.JPG (95.24 KiB) Viewed 3946 times
I have a few motion sensors, but this one has no persistence like somePIR do, so it is identical to your doorbell. My event fires a 433Mhz buzzer in my home, then turns it off after 5 seconds. It works really well.
It seems you are trying to do same thing as I was.
