Did I something wrong...
Doorbell stays "on"
pecora
Doorbell stays "on"
I try to build an event with my doorbell, it needs to be "off" but it stays always "on".
LJ80
Re: Doorbell stays "on"
I think you need to give more info, what event, which type of doorbell etc.pecora wrote:I try to build an event with my doorbell, it needs to be "off" but it stays always "on".
- bizziebis
- Domoticz version: 3.8805
You could edit your doorbell switch and add an off delay of 5 seconds or so.
Heisenberg
without more info or screenshots it's error guessing
Raspberry Pi Type B
Raspberry Pi Type B2
RFXCOMtrx433e
RFXCOMtrx433e
badubo
same issue, did you find any solution?
pj-r
- Domoticz version: V3.8650
If you dont have off button in your doorbell you have to edit it and set off delay manually. Or how do you think it knows to go back to off state. Same thing with PiR..
- StanHD
I don't think you need to turn it off.
I pause my Sonos like this:-
My doorbell switch is always on but blockly waits for a "new" on before it triggers again. I just press the Sonos switch back on again to resume play.
Python:- Broadlink RM2, Sonos
- G3rard
- Target OS: -
- Domoticz version: No
The doorbell in Domoticz does not have an off delay.
I have solved this by making a virtual switch and a LUA script that turns that switch on when the doorbell is rang. In that virtual switch I have set an off delay of 10 seconds.
If you use that switch in your commands (eg pause TV) then it will work.
LUA code
LUA code
if (devicechanged['doorbell']) then
if otherdevices['virtual_doorbell_switch']=='Off' then
commandArray['virtual_doorbell_switch']='On'
Not using Domoticz anymore
- Mediacj
Nice solution but a short period before it gone off after a short time at itself. I used it to put my tv on pause and to automatically switch the light at the door
Maybe there has been changed something.
pj-r
Oh, didnt know thatG3rard wrote:The doorbell in Domoticz does not have an off delay.
You could do the same thing then with "push on" button and off delay.. or pir.. or.. of course it would lead to wrong icon.
smokinjoev
Here is my setup for a driveway buried magnetic sensor that alerts me with a tone when someone drives up my driveway....
I have a few motion sensors, but this one has no persistence like somePIR do, so it is identical to your doorbell. My event fires a 433Mhz buzzer in my home, then turns it off after 5 seconds. It works really well.
It seems you are trying to do same thing as I was.
