Humidity and motion on 1 nano
Posted: Thursday 16 July 2015 19:26
by remb0
I had 2 nano's and wnat to combine them.
so now I have a nano with dht22 and motion.
the sketch for humidity and temp is still on it and working.
I have the dht on pin 3, and the motion on D4.
I want to report them both in 30 seconds but can somebody tell me how to combine? the sketches?
#include <SPI.h>
#include <MySensor.h>
#include <DHT.h>
#define CHILD_ID_HUM 0
#define CHILD_ID_TEMP 1
#define HUMIDITY_SENSOR_DIGITAL_PIN 3
unsigned long SLEEP_TIME = 30000; // Sleep time between reads (in milliseconds)
MySensor gw;
DHT dht;
float lastTemp;
float lastHum;
boolean metric = true;
MyMessage msgHum(CHILD_ID_HUM, V_HUM);
MyMessage msgTemp(CHILD_ID_TEMP, V_TEMP);
void setup()
  gw.begin();
  dht.setup(HUMIDITY_SENSOR_DIGITAL_PIN);
  // Send the Sketch Version Information to the Gateway
  gw.sendSketchInfo("Humidity", "1.0");
  // Register all sensors to gw (they will be created as child devices)
  gw.present(CHILD_ID_HUM, S_HUM);
  gw.present(CHILD_ID_TEMP, S_TEMP);
  metric = gw.getConfig().isMetric;
void loop()
  delay(dht.getMinimumSamplingPeriod());
  float temperature = dht.getTemperature();
  if (isnan(temperature)) {
      Serial.println("Failed reading temperature from DHT");
  } else if (temperature != lastTemp) {
    lastTemp = temperature;
    if (!metric) {
      temperature = dht.toFahrenheit(temperature);
    gw.send(msgTemp.set(temperature, 1));
    Serial.print("T: ");
    Serial.println(temperature);
  float humidity = dht.getHumidity();
  if (isnan(humidity)) {
      Serial.println("Failed reading humidity from DHT");
  } else if (humidity != lastHum) {
      lastHum = humidity;
      gw.send(msgHum.set(humidity, 1));
      Serial.print("H: ");
      Serial.println(humidity);
  gw.sleep(SLEEP_TIME); //sleep a bit
#include <SPI.h>
unsigned long SLEEP_TIME = 120000; // Sleep time between reports (in milliseconds)
#define DIGITAL_INPUT_SENSOR 3   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
#define INTERRUPT DIGITAL_INPUT_SENSOR-2 // Usually the interrupt = pin -2 (on uno/nano anyway)
#define CHILD_ID 1   // Id of the sensor child
MySensor gw;
// Initialize motion message
MyMessage msg(CHILD_ID, V_TRIPPED);
void setup()
  gw.begin();
  // Send the sketch version information to the gateway and Controller
  gw.sendSketchInfo("Motion Sensor", "1.0");
  pinMode(DIGITAL_INPUT_SENSOR, INPUT);      // sets the motion sensor digital pin as input
  gw.present(CHILD_ID, S_MOTION);
void loop()
  // Read digital motion value
  boolean tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
  Serial.println(tripped);
  gw.send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
  // Sleep until interrupt comes in on motion sensor. Send update every two minute.
  gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
Re: Humidity and motion on 1 nano
Posted: Friday 17 July 2015 10:01
by ThinkPad
Have you tried putting in the lines of code from the motion sketch into the temp lines? You will find lines that are equal, but also different lines. The last ones should be put in the correct place.
Big chance that it could be as simple like that. And pay attention to the node ID's of the temp/hum and motion, should not be equal.
Posted: Friday 17 July 2015 13:17
by remb0
my concerns are:
can I send two dirrent sketchinfos?
what is handy for sleeptime?
I gonna try this one tonight.
#include <SPI.h>
#include <DHT.h>
#define CHILD_ID 1
#define HUMIDITY_SENSOR_DIGITAL_PIN 2
MySensor gw;
DHT dht;
float lastTemp;
float lastHum;
void setup()
  gw.begin();
void loop()
    if (!metric) {
      lastHum = humidity;
Posted: Friday 17 July 2015 17:57
by remb0
1
send: 1-1-0-0 s=1,c=1,t=16,pt=0,l=1,st=ok:1
Posted: Friday 17 July 2015 18:00
by remb0
wORKS GREAT!:
#include <SPI.h>
#include <DHT.h>
#define CHILD_ID_MOT 2   // Id of the sensor child
#define HUMIDITY_SENSOR_DIGITAL_PIN 4
MySensor gw;
DHT dht;
float lastTemp;
float lastHum;
MyMessage msgMot(CHILD_ID_MOT, V_TRIPPED);
void setup()
  gw.begin();
  gw.sendSketchInfo("Humidity/Motion", "1.0");
  gw.present(CHILD_ID_MOT, S_MOTION);
void loop()
  gw.send(msgMot.set(tripped?"1":"0"));  // Send tripped value to gw
    if (!metric) {
      lastHum = humidity;
Posted: Friday 17 July 2015 22:42
by ThinkPad
What was the solution in the end?
Posted: Saturday 01 October 2016 10:13
by dudeffs
Hello I'm new to Arduino and I'm having a problem with this code. It won't send any data to the Serial Monitor apart from one random letter.
Can somebody help?
Posted: Monday 03 October 2016 12:47
by pj-r
dudeffs wrote:Hello I'm new to Arduino and I'm having a problem with this code. It won't send any data to the Serial Monitor apart from one random letter.
Can somebody help?
Wrong baud rate setting at arduino serial monitor?
