Humidity and motion on 1 nano
remb0
Post by remb0 »
I had 2 nano's and wnat to combine them.
so now I have a nano with dht22 and motion.
the sketch for humidity and temp is still on it and working.
I have the dht on pin 3, and the motion on D4.
I want to report them both in 30 seconds but can somebody tell me how to combine? the sketches?
#include <SPI.h>
#include <MySensor.h>
#include <DHT.h>
#define CHILD_ID_HUM 0
#define CHILD_ID_TEMP 1
#define HUMIDITY_SENSOR_DIGITAL_PIN 3
unsigned long SLEEP_TIME = 30000; // Sleep time between reads (in milliseconds)
MySensor gw;
DHT dht;
float lastTemp;
float lastHum;
boolean metric = true;
MyMessage msgHum(CHILD_ID_HUM, V_HUM);
MyMessage msgTemp(CHILD_ID_TEMP, V_TEMP);
void setup()
  gw.begin();
  dht.setup(HUMIDITY_SENSOR_DIGITAL_PIN);
  // Send the Sketch Version Information to the Gateway
  gw.sendSketchInfo("Humidity", "1.0");
  // Register all sensors to gw (they will be created as child devices)
  gw.present(CHILD_ID_HUM, S_HUM);
  gw.present(CHILD_ID_TEMP, S_TEMP);
  metric = gw.getConfig().isMetric;
void loop()
  delay(dht.getMinimumSamplingPeriod());
  float temperature = dht.getTemperature();
  if (isnan(temperature)) {
      Serial.println("Failed reading temperature from DHT");
  } else if (temperature != lastTemp) {
    lastTemp = temperature;
    if (!metric) {
      temperature = dht.toFahrenheit(temperature);
    gw.send(msgTemp.set(temperature, 1));
    Serial.print("T: ");
    Serial.println(temperature);
  float humidity = dht.getHumidity();
  if (isnan(humidity)) {
      Serial.println("Failed reading humidity from DHT");
  } else if (humidity != lastHum) {
      lastHum = humidity;
      gw.send(msgHum.set(humidity, 1));
      Serial.print("H: ");
      Serial.println(humidity);
  gw.sleep(SLEEP_TIME); //sleep a bit
#include <SPI.h>
unsigned long SLEEP_TIME = 120000; // Sleep time between reports (in milliseconds)
#define DIGITAL_INPUT_SENSOR 3   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
#define INTERRUPT DIGITAL_INPUT_SENSOR-2 // Usually the interrupt = pin -2 (on uno/nano anyway)
#define CHILD_ID 1   // Id of the sensor child
MySensor gw;
// Initialize motion message
MyMessage msg(CHILD_ID, V_TRIPPED);
void setup()
  gw.begin();
  // Send the sketch version information to the gateway and Controller
  gw.sendSketchInfo("Motion Sensor", "1.0");
  pinMode(DIGITAL_INPUT_SENSOR, INPUT);      // sets the motion sensor digital pin as input
  gw.present(CHILD_ID, S_MOTION);
void loop()
  // Read digital motion value
  boolean tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
  Serial.println(tripped);
  gw.send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
  // Sleep until interrupt comes in on motion sensor. Send update every two minute.
  gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
ThinkPad
Re: Humidity and motion on 1 nano
Post by ThinkPad »
Have you tried putting in the lines of code from the motion sketch into the temp lines? You will find lines that are equal, but also different lines. The last ones should be put in the correct place.
Big chance that it could be as simple like that. And pay attention to the node ID's of the temp/hum and motion, should not be equal.
remb0
Post by remb0 »
my concerns are:
can I send two dirrent sketchinfos?
what is handy for sleeptime?
I gonna try this one tonight.
#include <SPI.h>
#include <DHT.h>
#define CHILD_ID 1
#define HUMIDITY_SENSOR_DIGITAL_PIN 2
MySensor gw;
DHT dht;
float lastTemp;
float lastHum;
void setup()
  gw.begin();
void loop()
    if (!metric) {
      lastHum = humidity;
remb0
Post by remb0 »
1
send: 1-1-0-0 s=1,c=1,t=16,pt=0,l=1,st=ok:1
remb0
Post by remb0 »
wORKS GREAT!:
#include <SPI.h>
#include <DHT.h>
#define CHILD_ID_MOT 2   // Id of the sensor child
#define HUMIDITY_SENSOR_DIGITAL_PIN 4
MySensor gw;
DHT dht;
float lastTemp;
float lastHum;
MyMessage msgMot(CHILD_ID_MOT, V_TRIPPED);
void setup()
  gw.begin();
  gw.sendSketchInfo("Humidity/Motion", "1.0");
  gw.present(CHILD_ID_MOT, S_MOTION);
void loop()
  gw.send(msgMot.set(tripped?"1":"0"));  // Send tripped value to gw
    if (!metric) {
      lastHum = humidity;
ThinkPad
Post by ThinkPad »
What was the solution in the end?
dudeffs
Post by dudeffs »
Hello I'm new to Arduino and I'm having a problem with this code. It won't send any data to the Serial Monitor apart from one random letter.
Can somebody help?
pj-r
Domoticz version: V3.8650
Post by pj-r »
dudeffs wrote:Hello I'm new to Arduino and I'm having a problem with this code. It won't send any data to the Serial Monitor apart from one random letter.
Can somebody help?
Wrong baud rate setting at arduino serial monitor?
