Error executing script command lua returned: 512
romeok01
Domoticz version: 2.2563
Post by romeok01 »
I have problem with script in lua.
I write simple script in lua:
 if (devicechanged['LED Zielona'] == 'On')  then
    commandArray['LED Czerwona']='On'
Name this file is: led.lua and i move this in folder: /home/pi/domoticz/scripts/lua
This is switch in my Domoticz
I copy link for my script lua.led, to switch script, is: script://home/pi/domoticz/scripts/lua/led.lua
When i turn on my LED Zielona sript led.lua not working :(
I have Domoticz v. 2.2653.
In log i have error:
Error executing script command (/home/pi/domoticz/scripts/lua/led.lua). returned: 512
When i run my script in console (sudo lua led.lua) i have error:
lua: led.lua:2: attempt to index global 'devicechanged' (a nil value)
stack traceback:
led.lua:2: in main chunk
[C]: in ?
Please help me.
roblom
Re: Error executing script command lua returned: 512
Post by roblom »
Rename the la script to "script_device_led.lua".
Remove the link on the switch. Then it should work.
Lua knows the state of the switches so you don't have to let the switch start the script. The lua script executes when the switch is correctly programmed.
romeok01
Post by romeok01 »
Thank You Very Much roblom :)
Now its work :)
elgarne
Post by elgarne »
I'm in the same situation (error 512) and this is a workaround not the solution to this problem.
As stated in other threads, each script_device* script is executed each time a device state is changed. Thus, the more script_device* scripts you have, the most time it takes. Hence having a non script_device* script is interesting since it is executed only when required.
jvdz
Domoticz version: 4.107
Post by jvdz »
Not sure if there is a question in your post, but I am using one script_device_main.lua script which is the only script fired when a device changes. It has a bunch of if's which will run the appropriate LUA script when the if is true by using the dofile() command.
This keeps the number of ran script to a minimum and it did speed up the whole process.
Jos
elgarne
Post by elgarne »
Yes, I understand but it is still a workaround.
domoticz is supposed to execute a script from a switch's "on" or "off" action, if the right path to the script is provided. Nevertheless, it returns a 512 error in such a case and I'd like to know how to fix this issue.
jvdz
Post by jvdz »
So, why are you getting the 512? what are the error details?
Jos
elgarne
Post by elgarne »
If the file is renamed to script_device_CheckPresence.lua and has an
if devicechanged['mydevice']
statement, it works perfectly. But if executed through the on action of a dummy switch, then it generates the following error:
Error: Error executing script command (/home/pi/domoticz/scripts/lua/CheckPresence.lua). returned: 512
I googled for this error and all the threads I found about it have a similar workaround than the one you suggested. Some suggest to make the file executable etc but no solution seems to fix the issue.
jvdz
Post by jvdz »
That makes sense as these extra Tables are not available when the script is manually shelled or through the On/Off action of a switch.
They are only available when you use the standard lua event system by using script_trigger_name.lua and stored in domoticz\scripts\lua.
Jos
