i found out the hard way that my doorbell is conflicting with my OWL CM119 energy monitor and i have to choose between the 2
anyway anyone recommend a doorbell that doesn't use the byron SX protocol, anything that uses AC? preferably cheap... lol
If so, what's the meaning of protocol named "AD/LightwaveRF"? Does both have to be enabled to get LightwaveRF devices working?LightwaveRF is also using the Byron SX protocol!
even if it didn't use the Byron SX, the AD/LightwaveRF protocol also affects Oregon given as one of the examples in the UserGuide 2.4oopee wrote:If so, what's the meaning of protocol named "AD/LightwaveRF"? Does both have to be enabled to get LightwaveRF devices working?LightwaveRF is also using the Byron SX protocol!
Kaku chimes dont have UK/3 pin plug back to the drawing board for me...lolb_weijenberg wrote:LightwaveRF is also using the Byron SX protocol!
Double post:
The KAKU chimes use the AC protocol and can be used together with Oregon 3.0/OWL
http://www.klikaanklikuit.nl/shop/nl/pr ... eurbellen/
If the AD/LightwaveRF protocol is only used for their lighting products, surely there is never a need to have this checked. I understood that the Lightwaverf lighting doesn't send any status feedback and the RFXtrx433 was able to transmit on all regardless of what protocols were checked. Have I missed something really obvious?b_weijenberg wrote:The AD/LightwaveRF is only used for the 433.92MHz lighting products!
Check chapter 2 in the RFXtrx User Guide for the full list of supported devices. Tecknet is not in this list.
