User based on ip address
Posted: Friday 19 June 2015 0:56
by pepijn
By default all devices connecting to Domoticz from the internal network are logged in as admin user. I have several devices that i would like to login as a different user. (Tablets on the wall). A simple solution could be to add an IP address field to the user record, and if a device connects from that ip the assigned user is used to login.
Re: User based on ip address
Posted: Sunday 09 August 2015 11:38
by gizmocuz
You can add those ip addresses in the local network setting in the settings page
Posted: Sunday 09 August 2015 12:16
by Raspberry Piet
I also like this to achieve, can't see how to set it in the settings?
Posted: Sunday 16 August 2015 18:41
by gizmocuz
Okey, I got some ideas.... now the time to implement it
Posted: Thursday 07 January 2016 0:57
by pepijn
Could you share your ideas
