Can't interrupt "On Delay" or "Off Delay" timer
jin
Post by jin »
Hi All,
I want use a Virtual Switch as timer (count down timer) for my Domoticz Alarm System.
When a violation is detected I turn on that Virtual Switch with "On Delay = 30 seconds".
if I turn off the alarm within 30 seconds, I want stop the On Delay so the switch never turn On, but I can't find a way to accomplish that.
let's explain better with a API JSON example:
Turn On the switch:
http://localhost:8080/json.htm?type=com ... itchcmd=On
the "On Delay" start and the switch will turn On to 30 seconds.
after 5 seconds I run:
http://172.16.1.10:8080/json.htm?type=c ... tchcmd=Off
but the switch anyway will turn On after 30 seconds.
anyone have a suggestion to accomplish this task? (create a "interruptible" countdown timer)
this is can be an useful Feature Request?
With kind regards
mrf68
Re: Can't interrupt "On Delay" or "Off Delay" timer
Post by mrf68 »
I did some testing on version 2.2574 and it acts like you described. But it's not the way you want it to work. How can we accomplish this?
There is a switch that is activating the count down timer. I'll name it [Countdown activate]. There is switch that acts as a counter, I'll call it [Countdown timer]. You can create an event like this:
If [Countdown activate] = 'On'
Do Set [Countdown timer] = 'On' after '30' seconds
Else if [Countdown activate] = 'Off'
Do Set [Countdown timer] = 'Off'
Result:
When I turn [Countdown activate] to 'On' when [Countdown timer] is 'Off', then after 30 seconds [Countdown timer] turns 'On'.
When I turn [Countdown activate] to 'Off' when [Countdown timer] is 'On', it turns [Countdown timer] to 'Off'.
When I turn [Countdown activate] to 'On' and within 30 seconds I turn [Countdown activate] to 'Off', [Countdown timer] will stay 'Off'.
jin
Post by jin »
mrf68 wrote: If [Countdown activate] = 'On'
Hi mrf68,
thank you very much for the fast reply and the useful suggestion!!!
Just tried and works perfectly! :)
This setup involve the creation of two virtual devices for every incorruptible countdown timer, but make possible to accomplish this challenge :)
Anyway, some days ago I opened a Feature Ticket [529] http://www.domoticz.com/forum/tracker.php?p=2&t=529
with an "idea" to make a more easy system to manage "count down timers" using special variables.
This must be developed and I don't know if implementing "special variables of this type" is a good way to manage this need, anyway creating many virtual devices, IMHO add useless complexity and can be simplified in other ways :)
If someone else appreciate the feature request, support it adding a note into 529 ticket ;)
With kind regards.
mrf68
Post by mrf68 »
jin wrote: Hi mrf68,
You're welcome. Together we'll make it work. (Could be a slogan?)
Kind regards,
Olinelooo
Post by Olinelooo »
I don't know if implementing "special variables of this type" is a good way to manage this need, anyway creating many virtual devices, IMHO add useless complexity and can be simplified in other ways :)????
