Sun position in lua
Posted: Friday 05 June 2015 19:11
Hi everybody,
After reading this post http://www.domoticz.com/forum/viewtopic.php?f=23&t=6451. I choose to share a script I just write.
I've write this script using info from here http://www.plevenon-meteo.info/techniqu ... ement.html.
It gives you sun position and theoretical sun radiation. This could help you to close or open blinds, know how cloudy is the sky if you have pyranometer, and what ever you may imagine.
I'm actually testing it. Any comments, suggestions, corrections are welcome.
I did not succeed retrieving longitude and latitude in lua. If you have any idea, let me know.
To make it work you need to modify latitude, longitude.
If you use altitude correction you need to modify barometer device and altitude.
Modify the end of the script to fill your needs.
--Script lua sun v0.01
--Make from info found http://www.plevenon-meteo.info/technique/theorie/enso/ensoleillement.html
--Variables
-- Debug Option
debug = true -- true or false
-- Position variables of your location - To edit
longitude = X.XXXX -- degrees
latitude = X.XXXX -- degrees
-- Calculation with altitude (you need a barometer !)
CalculationWithAltitude = true -- true or false
altitude = XXX -- meters
Barometer = 'Baromètre' -- hPa -- Your barometer must report relative pression (value from sensor with altitude correction)
-- Solar Variables
SolarConstantW = 1361 -- W/m²
SolarConstantLux = 200000 -- Lux
--Calculations code
function round(num, idp)
local mult = 10^(idp or 0)
return math.floor(num * mult + 0.5) / mult
if ( debug == true ) then
print ("------------SUN_START------------")
-- Calculation of day number
DayNumber = os.date("%j")
print ("Today is day number "..DayNumber)
-- Calculation of solar declination
SolarDeclination = 23.45 * math.sin(math.rad(360 * ( 284 + DayNumber ) / 365 ))
print ("Solar declination is "..SolarDeclination.." degrees")
--Calculation of decimal UTC time
DecimalTime = os.date("!%H") + os.date("!%M") / 60
print ("Decimal UTC time is "..DecimalTime.." hour")
-- Solar Time
SolarTime = DecimalTime + (4 * longitude / 60 )
print ("Solar time is "..SolarTime.." hour")
-- Calculation of hour angle
HourAngle = 15 * ( 12 - SolarTime )
print ("Hour angle is "..HourAngle.." degrees")
-- Calculation of solar tilt
SolarTilt = math.deg(math.asin(math.sin(math.rad(latitude)) * math.sin(math.rad(SolarDeclination)) + math.cos(math.rad(latitude)) * math.cos(math.rad(SolarDeclination)) * math.cos(math.rad(HourAngle))))
print ("Solar tilt is "..SolarTilt.." degrees")
-- Calculation of solar flux
SolarFlux = SolarConstantW * (1 +0.034 * math.cos( math.rad( 360 * DayNumber / 365 )))
print ("Solar flux is "..SolarFlux.." W/m²")
-- Calculation of solar tilt sinus
SinusSolarTilt = math.sin(math.rad(SolarTilt))
-- Calculation of M0
M0 = math.sqrt(1229 + math.pow(614 * SinusSolarTilt,2)) - 614 * SinusSolarTilt
print ("M0 equal "..M0)
-- Calculation of M
if (CalculationWithAltitude == true) then
sBaroTemp, sBaroPressure, sUnknow1, sUnknow2 = otherdevices_svalues[Barometer]:match("([^;]+);([^;]+);([^;]+);([^;]+)")
P = tonumber(sBaroPressure) -- hPa
P0 = P - round((altitude / 8.3),1) -- hPa
print ("Relative pression is "..P.." hPa")
print ("Absolute pression is "..P0.." hPa")
M = M0 * P / P0
M = M0
print ("M equal "..M)
-- Calculation of direct radiation
DirectRadiation = SolarFlux * math.pow(0.6,M) * SinusSolarTilt
print ("Direct radiation is "..DirectRadiation.." W/m²")
-- Calculation of diffuse radiation
DiffuseRadiation = SolarFlux * (0.271 - 0.294 * math.pow(0.6,M)) * SinusSolarTilt
print ("Diffuse radiation is "..DiffuseRadiation.." W/m²")
-- Calculation of total radiation in W/m²
if (SolarTilt > 3) then
print ("Solar tilt is over 3 degrees")
TotalRadiationW = DirectRadiation + DiffuseRadiation
print ("Solar tilt is equal or under 3 degrees")
TotalRadiationW = 0
print ("Total radiation is "..round(TotalRadiationW,2).." W/m²")
-- Calculation of total radiation in Lux
TotalRadiationLux = SolarConstantLux / SolarConstantW * TotalRadiationW
print ("Total radiation is "..round(TotalRadiationLux).." Lux")
--Start of your code
--List of variables from calculations :
-- SolarDeclination : Solar declination in degrees
-- SolarTime : Solar time in hour
-- HourAngle : Hour angle in degrees
-- SolarTilt : Solar tilt in degrees
-- SolarFlux : Solar flux in W/m²
-- P : Relative pression in hPa ; Only with CalculationWithAltitude = true
-- P0 : Absolute pression in hPa ; Only with CalculationWithAltitude = true
-- DirectRadiation : Direct radiation in W/m²
-- DiffuseRadiation : Diffuse radiation in W/m²
-- TotalRadiationW : Total radiation in W/m²
-- TotalRadiationLux : Total radiation in Lux
idxRadiationCounter =
if (idxRadiationCounter ~= nil) then
commandArray['UpdateDevice'] = idxRadiationCounter .. "|0|" .. TotalRadiationLux
print ("Radiation counter updated")
print ("Radiation counter not set")
--End of your code
print ("-------------SUN_END-------------")
