Sun position in lua
arnaudth
Sun position in lua
Post by arnaudth »
Hi everybody,
After reading this post http://www.domoticz.com/forum/viewtopic.php?f=23&t=6451. I choose to share a script I just write.
I've write this script using info from here http://www.plevenon-meteo.info/techniqu ... ement.html.
It gives you sun position and theoretical sun radiation. This could help you to close or open blinds, know how cloudy is the sky if you have pyranometer, and what ever you may imagine.
I'm actually testing it. Any comments, suggestions, corrections are welcome.
I did not succeed retrieving longitude and latitude in lua. If you have any idea, let me know.
To make it work you need to modify latitude, longitude.
If you use altitude correction you need to modify barometer device and altitude.
Modify the end of the script to fill your needs.
--Script lua sun v0.01
--Make from info found http://www.plevenon-meteo.info/technique/theorie/enso/ensoleillement.html
--Variables
-- Debug Option
debug = true -- true or false
-- Position variables of your location - To edit
longitude = X.XXXX -- degrees
latitude = X.XXXX -- degrees
-- Calculation with altitude (you need a barometer !)
CalculationWithAltitude = true -- true or false
altitude = XXX -- meters
Barometer = 'Baromètre' -- hPa -- Your barometer must report relative pression (value from sensor with altitude correction)
-- Solar Variables
SolarConstantW = 1361 -- W/m²
SolarConstantLux = 200000 -- Lux
--Calculations code
function round(num, idp)
  local mult = 10^(idp or 0)
  return math.floor(num * mult + 0.5) / mult
if ( debug == true ) then
	print ("------------SUN_START------------")
-- Calculation of day number
DayNumber = os.date("%j")
	print ("Today is day number "..DayNumber)
-- Calculation of solar declination
SolarDeclination = 23.45 * math.sin(math.rad(360 * ( 284 + DayNumber ) / 365 ))
	print ("Solar declination is "..SolarDeclination.." degrees")
--Calculation of decimal UTC time
DecimalTime = os.date("!%H") + os.date("!%M") / 60
	print ("Decimal UTC time is "..DecimalTime.." hour")
-- Solar Time
SolarTime = DecimalTime + (4 * longitude / 60 )
	print ("Solar time is "..SolarTime.." hour")
-- Calculation of hour angle
HourAngle = 15 * ( 12 - SolarTime )
	print ("Hour angle is "..HourAngle.." degrees")
-- Calculation of solar tilt
SolarTilt = math.deg(math.asin(math.sin(math.rad(latitude)) * math.sin(math.rad(SolarDeclination)) + math.cos(math.rad(latitude)) * math.cos(math.rad(SolarDeclination)) * math.cos(math.rad(HourAngle))))
	print ("Solar tilt is "..SolarTilt.." degrees")
-- Calculation of solar flux
SolarFlux = SolarConstantW * (1 +0.034 * math.cos( math.rad( 360 * DayNumber / 365 )))
	print ("Solar flux is "..SolarFlux.." W/m²")
-- Calculation of solar tilt sinus
SinusSolarTilt = math.sin(math.rad(SolarTilt))
-- Calculation of M0
M0 = math.sqrt(1229 + math.pow(614 * SinusSolarTilt,2)) - 614 * SinusSolarTilt
	print ("M0 equal "..M0)
-- Calculation of M
if (CalculationWithAltitude == true) then
	sBaroTemp, sBaroPressure, sUnknow1, sUnknow2 = otherdevices_svalues[Barometer]:match("([^;]+);([^;]+);([^;]+);([^;]+)")
	P = tonumber(sBaroPressure) -- hPa
	P0 = P - round((altitude / 8.3),1) -- hPa
		print ("Relative pression is "..P.." hPa")
		print ("Absolute pression is "..P0.." hPa")
	M = M0 * P / P0
	M = M0
	print ("M equal "..M)
-- Calculation of direct radiation
DirectRadiation = SolarFlux * math.pow(0.6,M) * SinusSolarTilt
	print ("Direct radiation is "..DirectRadiation.." W/m²")
-- Calculation of diffuse radiation
DiffuseRadiation = SolarFlux * (0.271 - 0.294 * math.pow(0.6,M)) * SinusSolarTilt
	print ("Diffuse radiation is "..DiffuseRadiation.." W/m²")
-- Calculation of total radiation in W/m²
if (SolarTilt > 3) then
		print ("Solar tilt is over 3 degrees")
	TotalRadiationW = DirectRadiation + DiffuseRadiation
		print ("Solar tilt is equal or under 3 degrees")
	TotalRadiationW = 0
	print ("Total radiation is "..round(TotalRadiationW,2).." W/m²")
-- Calculation of total radiation in Lux
TotalRadiationLux = SolarConstantLux / SolarConstantW * TotalRadiationW
	print ("Total radiation is "..round(TotalRadiationLux).." Lux")
--Start of your code
--List of variables from calculations :
--	SolarDeclination	: Solar declination in degrees
--	SolarTime			: Solar time in hour
--	HourAngle			: Hour angle in degrees
--	SolarTilt			: Solar tilt in degrees
--	SolarFlux			: Solar flux in W/m²
--	P					: Relative pression in hPa ; Only with CalculationWithAltitude = true
--	P0					: Absolute pression in hPa ; Only with CalculationWithAltitude = true
--	DirectRadiation		: Direct radiation in W/m²
--	DiffuseRadiation	: Diffuse radiation in W/m²
--	TotalRadiationW		: Total radiation in W/m²
--	TotalRadiationLux	: Total radiation in Lux
idxRadiationCounter =
if (idxRadiationCounter ~= nil) then
	commandArray['UpdateDevice'] = idxRadiationCounter .. "|0|" .. TotalRadiationLux
		print ("Radiation counter updated")
		print ("Radiation counter not set")
--End of your code
	print ("-------------SUN_END-------------")
simonrg
Domoticz version: 3.8807
Re: Sun position in lua
Post by simonrg »
arnaudth wrote:I did not succeed retrieving longitude and latitude in lua. If you have any idea, let me know.
Nice script.
You get lattitude and longitude from this json call:
curl 'http://localhost:8080/json.htm?type=command&param=getconfig'
arnaudth
Post by arnaudth »
Thanx, I remember I tried this, but not working in my domoticz V2.2284
I got :
status: "ERR"
simonrg
Post by simonrg »
arnaudth wrote:Thanx, I remember I tried this, but not working in my domoticz V2.2284
I got :
status: "ERR"
No it won't because it wasn't introduced until about 2.25xx, however I remember back in 2.2284 then every device replied with its lattitude and longitude.
This was consolidated into getconfig - see this forum thread - http://www.domoticz.com/forum/viewtopic ... 90&p=43559
arnaudth
Post by arnaudth »
Thanx, however I'll wait for a stable release and then update my script.
assenzuid
Post by assenzuid »
I get below error
2016-04-07 22:48:00.343 LUA: ------------SUN_START------------
2016-04-07 22:48:00.343 LUA: Today is day number 098
2016-04-07 22:48:00.343 LUA: Solar declination is 6.7649130510503 degrees
2016-04-07 22:48:00.344 LUA: Decimal UTC time is 20.8 hour
2016-04-07 22:48:00.344 LUA: Solar time is 24.332648133333 hour
2016-04-07 22:48:00.344 LUA: Hour angle is -184.989722 degrees
2016-04-07 22:48:00.345 LUA: Solar tilt is -75.802997406671 degrees
2016-04-07 22:48:00.345 LUA: Solar flux is 1355.6352423383 W/m²
2016-04-07 22:48:00.345 LUA: M0 equal 1191.5260975059
2016-04-07 22:48:00.345 Error: EventSystem: in Sun Position: [string "--Script lua sun v0.01 ..."]:94: attempt to index field '?' (a nil value)
