Error: Error executing script returned: 65280
I 've got 2 RPI, one with domoticz (pi1), the other one with volumio (pi2).
I try to shutdwon by script pi2 from pi1.
I've got a script on pi1:
pi@raspberrypi ~/domoticz/scripts $ more stop-rpi2.sh
#!/bin/bash
# Script qui eteint le rpi volumio
ssh 192.168.1.116 "/home/pi/stop-volumio.sh"
on pi2 :
pi@RPI2:~$ more stop-volumio.sh
#!/bin/bash
# Script qui eteint le raspberry
sudo shutdown -h now
The copy off the ssh certificate is OK on pi2.
When I run stop-rpi2.sh from putty on pi1 the job is done.
When I run thz script using a switch on domoticz i've got this message :
Error: Error executing script command (/home/pi/domoticz/scripts/stop-rpi2.sh). returned: 65280
What can I do ?
#!/bin/bash
on pi2 :
#!/bin/bash
What can I do ?
Re: Error: Error executing script returned: 65280
Maybe a permission problem.
With a tool like WinSCP (Windows) you can see who the owner of the file is and what the rights are (read/write/execute etc). Make sure it has the same owner/permissions like the scripts from Domoticz itself.
Same owner, same permissions.
When I run the script in putty all is OK. The Pi2 is shutting down.
I call this script in domotics using à switch
I've got the error when I use this domoticz's switch. Error 65280 and no shutting down from pi2
- Domoticz version: 3.7253
Have the same problem, so did you find any solution to this problem?
Found it...
Seems that domoticz ssh tru root so just made a new ssh key with root instead.
- Domoticz version: 2022.1
@plutonium
Thank you
I've got the same issue. Could you elaborate your answer I don't quite understand it.Seems that domoticz ssh tru root so just made a new ssh key with root instead.
Thank you
Debian buster on NUC and three RPi with buster.
Did you make a ssh key so you don't need to use password for pi user?
Make one with root instead and your script will work.
Skickas från min iPhone via Tapatalk
Thanks plutonium. Indeed I made a key, but I did it this pi user not root user, hence it is working when I run it from putty. Ok I just started to understand that domoticz runs scripts with root context
Cheers
Cheers
This is working now.
- Target OS: -
Better 1: to call ssh with user parameter and move key into /root/.ssh etcetera..
Or check howto run domoticz as pi. Latest stable gives you the option to start domoticz as other user.
Grtz,
Stephan
Grtz,
Stephan
- Domoticz version: 4.
I can not understand the fix for this error.
My script is
#!/bin/bash
net rpc shutdown -t 10 -f -C "Shuting down computer" -I 192.168.1.99 -U user%pass -d 1
The script Works and the main computer is shutdown but in domoticz log i get rhe message:
Error executing script command (/opt/domoticz/scripts/pcapagar.sh). returned: 65280
Why?
My script is
#!/bin/bash
Why?
