Volunteer for new plugin development
dberenguer
Hi community!
I'm the founder of an open hardware (wireless) project called panStamp. We are trying to promote the integration with existing open HA software and for this we are providing free hardware kits to any developer interested in working on a plugin for Domoticz. This kit usually includes wireless sensors, relay board, USB interface and RGB strip driver but of course we can add more items if necessary.
At this moment three libraries are available (Python, Java and Perl) but none of them is compatible with C++. This means that porting the library to C++ should be necessary before developing the plugin. Anyone interested please contact me via PM, e-mail or simply by responding in this post.
Thanks for your time and congratulation to the Domoticz team!
Daniel.
Daniel.
- gizmocuz
Re: Volunteer for new plugin development
Hello Daniel,
Thank you for the offer.
It looks like MySensors ?
At the moment we are building more support for the mysensors system, using the NRF24L01
dberenguer
Thanks @guizmocuz,
panStamp relies on its own protocol, called SWAP. It's quite simple except for the fact that all the relevant information about devices is stored in static XML files. This makes the protocol lightweight on the network side but involves doing some more complex stuff by the host computer. On the other hand, this approach lets applications recognize new developments as far as new XML files are uploaded onto the central repository.
Regards,
Daniel.
Regards,
Daniel.
maluko
Cool, more compatible stuff are welcome.
dberenguer
We are in fact working on new hardware like a battery-powered CO2 meter and also a battery-powered current reader. I also forgot to say that panStamp is programmable from the Arduino IDE.maluko wrote:Cool, more compatible stuff are welcome.
Regards,
Daniel.
BigDog
- Domoticz version: V3.9269
is it also usable for peoples with little programming skills?
1X Raspberry4B : Domoticz Version 2023.1 [Linux 5.10.63-v7l+ armv7l]
1X Conbee II : 2.25.3 - 26720700
1X RFXtrx433 USB Firmware:183
1X Mysensors Gateway 1.5 -3
6X ESP8266: Tosmota firmware
Zigbee : 6 Operators, 13 Sensors
dberenguer
Yes. We provide sample applications for temperature, humidity or pressure measurement and also for relay and RGB strip control so you have only to install the Arduino IDE, patch the IDE with our cores/libraries, program the module through a panStick and finally power the module. Lots of users from the fhem community are doing this and we hope that users from the Domoticz and OpenHAB communities will be able to do it soon.BigDog wrote:is it also usable for peoples with little programming skills?
- gizmocuz
please do not implement it with scripts etc... but as a native c++ hardware deviceBigDog wrote:is it also usable for peoples with little programming skills?
dberenguer
I just wanted to give you an update about this project. We finally implemented MQTT on our lightweight lagarto gateway in order to provide integration with domoticz and with any other automation software:
Link to the blog post
This way our low-power wireless devices can interact with a huge amount of M2M platforms without having to create a specific plugin for each one.
Thanks guys for your support!
