Nest: thanks for implementing!
Posted: Tuesday 26 May 2015 6:04
by safi78
Can I just say that I'm VERY happy with the implementation of Nest in the latest beta? :D
Thanks so much gizmocuz!
Re: Nest: thanks for implementing!
Posted: Tuesday 26 May 2015 9:47
by meesje
Great to see Nest is supported.
Can you tell which functionalities of the Nest are supported? What can you do/see within Domoticz?
Posted: Tuesday 26 May 2015 11:07
by safi78
3 new devices:
Temp/Hum, Room SetPoint, and Away status
Screen Shot 2015-05-26 at 11.05.17.png (29.85 KiB) Viewed 3607 times
Screen Shot 2015-05-26 at 11.05.07.png (24.07 KiB) Viewed 3607 times
Screen Shot 2015-05-26 at 11.04.50.png (38.62 KiB) Viewed 3607 times
Posted: Tuesday 26 May 2015 11:11
by safi78
Probably the easiest hardware to setup ;)
Screen Shot 2015-05-26 at 11.10.57.png (99.58 KiB) Viewed 3603 times
Posted: Tuesday 26 May 2015 20:28
by Dlanor
It works perfectly! I have made an event switchen the Nest to away status when opening the backdoor via Domoticz. The system responds within 2 seconds.
Posted: Tuesday 26 May 2015 20:33
by safi78
That's a nice trick, I like!
Posted: Wednesday 27 May 2015 22:04
by mcpoowl
Yeah, great addition to an already great framework. Thanks gizmo <3
Posted: Thursday 11 June 2015 23:06
by rhamnett
Hi, I registered on the forum specifically just to say thanks for implementing the Nest feature. Great job :D :D
Posted: Friday 22 January 2016 19:45
by simon_rb
Received my 3rd Gen nest today and loving it. I got the status, temp and set temp to show up but they wouldn't refresh. Whatever was done on the nest didn't reflect in domoticz. Also I couldn't set the home/away status from domoticz. So I decided to to delete it all and start again. Now I don't have anything. How did you guys set yours up?
Kind Regards
Simon
Posted: Saturday 23 January 2016 10:53
by simon_rb
Right, I have it working where I can set home and away using blocky and seems to work fine. I think my issue is that its not getting updates from the Nest. I can set things from Domoticz but when I use the Nest App or the thermostat itself, those changes do no happen in Domoticz. I read somewhere it polls every 30 seconds or something like that. Inside Domoticz under utility they are showing up as red which I assume means no communication so i'm guessing domoticz is trying to communicate but its not getting a response.
Any ideas please share.
Thank you!!! :)
