Hue script Json Curl Windows not working.
Posted: Thursday 07 May 2015 17:21
Hello
Im new to scripting for domoticz and i'm trying to use my Hue lamp with curl and Json Scripts on a windows (2008) PC
I'm trying to start Easy
I want to switch my HUE lamp with Device ID 5 with a Json scirpt With a Dummy On/Off Switch named Hue1 (Type Lightnig 1, X10, On/Off)
(And yes i know it can be Easyer. But i want to start easy with Json later on i want use scene's groups etc...
What i did.
When i run in a "cmd box "on windows 2008
The lights turns on
and the lights turns off.
When i create .bat file with the name 5on.bat and 5off.bat and i run the .bat file the lighst switches on/off
The batch files are placed in And i like to keep them only there but i can't get it running from the "domoticz script map".
When i place 5on.bat and 5off.bat in the c:\ and use and I can see in the log the Script is excecuted but nothing happens.
What i want. I would love to keep the .bat file in the /scrips map.
Is it possible to use this Json code without the / strings? What's the right/easy way to use a json code in Domoticz?
How do i get the .bat file running?
What i did.
curl -X PUT -d "{\"on\":true}" http://192.168.1.15/api/myID/lights/5/stateCode: Select all
curl -X PUT -d "{\"on\":false}" http://192.168.1.15/api/myID/lights/5/stateWhen i create .bat file with the name 5on.bat and 5off.bat and i run the .bat file the lighst switches on/off
C:\Program Files (x86)\Domoticz\scriptsWhen i place 5on.bat and 5off.bat in the c:\ and use
script://5on.batCode: Select all
script://5off.batCode: Select all
2015-05-07 17:11:18.269 (Dummy) Lighting 1 (Hue1)
2015-05-07 17:11:19.106 Executing script: /5off.bat
2015-05-07 17:11:25.657 (Dummy) Lighting 1 (Hue1)
2015-05-07 17:11:26.127 Executing script: /5on.batIs it possible to use this Json code without the / strings? What's the right/easy way to use a json code in Domoticz?
