Hue script Json Curl Windows not working.
Tjeerd13
Post by Tjeerd13 »
Hello
Im new to scripting for domoticz and i'm trying to use my Hue lamp with curl and Json Scripts on a windows (2008) PC
I'm trying to start Easy :)
I want to switch my HUE lamp with Device ID 5 with a Json scirpt With a Dummy On/Off Switch named Hue1 (Type Lightnig 1, X10, On/Off)
(And yes i know it can be Easyer. But i want to start easy with Json later on i want use scene's groups etc... ;) )
What i did.
When i run in a "cmd box "on windows 2008
curl -X PUT -d "{\"on\":true}" http://192.168.1.15/api/myID/lights/5/state
The lights turns on :D
curl -X PUT -d "{\"on\":false}" http://192.168.1.15/api/myID/lights/5/state
and the lights turns off. :D
When i create .bat file with the name 5on.bat and 5off.bat and i run the .bat file the lighst switches on/off :D
The batch files are placed in
C:\Program Files (x86)\Domoticz\scripts
And i like to keep them only there but i can't get it running from the "domoticz script map".
When i place 5on.bat and 5off.bat in the c:\ and use
script://5on.bat
and
script://5off.bat
I can see in the log the Script is excecuted but nothing happens.
2015-05-07 17:11:18.269 (Dummy) Lighting 1 (Hue1)
2015-05-07 17:11:19.106 Executing script: /5off.bat
2015-05-07 17:11:25.657 (Dummy) Lighting 1 (Hue1)
2015-05-07 17:11:26.127 Executing script: /5on.bat
What i want. I would love to keep the .bat file in the /scrips map.
Is it possible to use this Json code without the / strings? What's the right/easy way to use a json code in Domoticz?
How do i get the .bat file running?
Pi3, Pi4, Pi4 for Testing, Dashticz, RFXtrx433, Nest: "Thermostat V2, V3, Hello". Honywell Lyric T6R, RFXCom, KaKu, HUE, P1, Open Zwave USB,
ThinkPad
Re: Hue script Json Curl Windows not working.
Post by ThinkPad »
Have you tried other .bat scripts to see if that works? A simple test script that creates a .txt file or something?
Tjeerd13
Post by Tjeerd13 »
I make a test.bat add the c:\
cd\
md test
When i run the .bat file manualy it create a dir.
When i run it with the dumy switch nothing happening only a message in the log file with
Executing script: /test.bat
thats indicates thath the file is found.
Help :D :o :o ;)
matt
Domoticz version: 2.2657
Post by matt »
I have this issue, did you find a fix??
Tjeerd13
Post by Tjeerd13 »
No i did not... I bought a Raspberry II [FACE SAVOURING DELICIOUS FOOD]
foggy75
Post by foggy75 »
I had the same problem, and figured out how to make it work:
First, rename the batch file _domoticz_main.bat file to domoticz_main.bat in the scripts folder.
Now this script will get executed each time you toggle a switch.
In this sample script however, there is a problem caused by the default install location for domoticz on windows has spaces in the pathname, which leads to the variables inside the main batch file not being set correctly.
To fix this, update set commands in the batch file like this:
REM due to install location containing spaces, parameters %1 through %3 are all pieces of the startup_path
set startup_path=%1 %2 %3
set hardware_id=%4
set device_id=%5
set status=%6
set status2=%7
set devname=%8
Then from this script I could launch my custom script using the path, devname and status variables.
Another trick for troubleshooting: add the pause command at the end of the domoticz_main.bat file, this will cause the window to stay open until a key is pressed...
