Make EM6590 smoke alarm beep?
Posted: Thursday 07 May 2015 15:57
by arjanvdwiel
I have a few Eminent EM6590 smoke detectors, which i can detect in domoticz.
When i press the (test) button on the smoke alarm, the domoticz-status is changed to 'on'.
But is there any way to trigger the alarms from domoticz? This way i can sync them so they all go off simultaneously?
Re: Make EM6590 smoke alarm beep?
Posted: Thursday 07 May 2015 17:21
by D'rMorris
Yes, there is
. For example, if you have a PIR and you want the smoke detector to go off on motion you use:
if (devicechanged['PIR'] == 'On')
then
print('Motion detected')
commandArray['SendNotification']='Motion detected#Motion detected somewhere!#2'
commandArray['SMOKEDETECTOR']='On'
Posted: Thursday 07 May 2015 20:39
by Derik
D'rMorris wrote:Yes, there is
then
And where do i have to place this?
Posted: Thursday 07 May 2015 20:43
by D'rMorris
Start by reading how to use LUA in the wiki:
http://domoticz.com/wiki/Main_Page
Posted: Friday 08 May 2015 10:41
by arjanvdwiel
The smoke detector is shown as a switch. When i switch it 'on' in domoticz, it doesnt start beeping..
So i guess a lua script wont work..
Posted: Friday 08 May 2015 10:52
by Egregius
I guess something else is wrong then.
I can test my smoke detectors by clicking the icon and let them beep with blocky. Should be possible in LUA also then.
Posted: Friday 08 May 2015 12:00
by D'rMorris
arjanvdwiel wrote:The smoke detector is shown as a switch. When i switch it 'on' in domoticz, it doesnt start beeping..
It should be shown as a KD-101 and a fire icon, not a switch. Perhaps you can post a screenshot of the culprit?
Posted: Friday 08 May 2015 14:20
by arjanvdwiel
This is how i see them in domoticz
Posted: Friday 08 May 2015 14:22
by Egregius
Clicking on the round icon with flames does nothing?
Nevermind the KD-101 type, that's 433Mhz version (like mine and D'rMorris).
Posted: Friday 08 May 2015 15:15
by arjanvdwiel
Clicking on the flames turns them on, and reset turns them off.
But no sound..
Posted: Sunday 10 January 2016 17:46
by rik82
I have the same problem. Can't send on signal to pt2262 smoke detector...
Posted: Wednesday 09 March 2016 18:38
by proohu01
Hi arjanvdwiel,
Would you mind sharing you smoke detector icon on the forum? (or PM) I like it and there is nothing in Domoticz like that by default.
Also, how did you get a reset button and how do you send this command to the smoke detector?
Posted: Wednesday 09 March 2016 18:41
by jvdz
The shown Icon and reset button are there with a standard installation for me (Everspring SF812 Smoke Alarms)
Jos
Posted: Wednesday 09 March 2016 19:06
by proohu01
My bad! Looking in the wrong place. Found it. Sorry for hijacking this post.
Posted: Wednesday 16 March 2016 13:43
by adsernl
All,
i got the same problem with my pt2262 smoke detector. How can i make it beep?
thanks already
